NOTICE Notice: This is an old thread. The last post was 2833 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Default Question about E.Howard Co. N size watch winding stem
    Hello and thank you firstly ~
    I would like to ask did the E.Howard Co. N size pocket watch have different structure than "general" 18 size pocket watch ?
    Why I ask about it because I found N size E.Howard have additional screw on the stem seem to fix it... it cannot found on other 18 size watch.
    Did that screw is use to fix the stem instead of fix the stem by the case ?
    Thank you very much ~
    Registered user.
    Aug 2004
    Apache Jct AZ
    951
    Default Re: Question about E.Howard Co. N size watch winding stem (By: pppdddaaa)
    Yes there is a screw to hold the stem in place, it is called a detente screw, on the movement next to the hole for the stem. The N size Howard movement is larger than a normal 18 size movement so the case that fits them is hard to come by. Hope this helps.
    Default Re: Question about E.Howard Co. N size watch winding stem (By: Bill B)
    I think I got the answer
  1. Question about these Howard movement numbers
    By richiec in forum American Pocket Watches
    Last Post: 11-04-2008, 04:46 AM
  2. Question about original Accutron Hang tag on watch
    By rjbeck in forum Wrist Watches
    Last Post: 04-02-2008, 07:01 PM
  3. Question about Lepina (with an "a") pocket watch
    By Kent in forum American Pocket Watches
    Last Post: 09-09-2005, 02:01 AM
  4. Question on E. Howard & Co."N" size
    By Jon Hanson in forum American Pocket Watches
    Last Post: 11-01-2000, 09:33 AM
