NOTICE Notice: This is an old thread. The last post was 2751 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 2 of 2
    Default Vibrograf 390 manual or inking info.
    Hi,
    I just picked up an old Vibrograf 390, and after a few initial problems, appear to have it functioning.
    However I cannot work out how to ink the tape.
    I suspect it was of the type where you just added ink, as it would be a huge job to remove it. (Major disassemble by all appearances)
    Before I just go dumping stamp pad ink onto the tape, I thought it may be better to see if anyone here has instructions or experience with this.
    I did contact Vibrograf, who were most helpful, but they don't have the 390 info.
    I do now have copies of B100, B200A, and Chronografic manuals BTW, thanks to Vibrograf, and members here. (If anyone wants copies send me an email- watchwerx@bigpond.com)
    All the above machines used thermal or combo with ink ribbon, but the ribbon setups are completely different to this one.
    Would kill for a manual, but any info as to the ink tape would be much appreciated.
    Thanks in advance,
    Offshore
    Registered User terofpa's Avatar
    Dec 2006
    Lavelle, Pa
    420
    Default Re: Vibrograf 390 manual or inking info. (RE: offshore1)
    I don't know if this helps you but I bought a universal replacement typewriter ribbon from an office supply store for my B100. Worked fine with a little modification.
    I read where others used thermal paper of the correct width for machines with dried out ribbons. That also worked for me but the lines weren't as dark as I liked.
    ter
  1. Need help or any info
    By Kulitko in forum Clocks General.
    Last Post: 06-25-2012, 05:26 PM
  2. Vibrograf 390
    By Shenlun in forum Horological Tools
    Last Post: 12-22-2009, 02:28 AM
  3. Electrical Wristwatch Service manuals or diagrams for V236A quartz movement?
    By schweige in forum Watch Repair
    Last Post: 11-12-2006, 04:12 AM
  4. Dutch Hood or "Tale " Clock Info please
    By Carroll Hardin in forum Clock Repair
    Last Post: 02-17-2006, 12:05 PM
  5. VIBROGRAF INTERPRETATION OF RECORDS MANUALS
    By teaguepawn in forum Watch Repair
    Last Post: 11-23-2005, 10:22 AM
