Goal: $300, Received: $215.00 (72%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2930 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 1 of 1
    Default August. Tuning Fork Clock. Louis-Clément Breguet
    Paris
    Tuning-fork clock
    Nickel-plated metal, brass, steel
    Height: 46 cm. Width: 26 cm. Depth: 19 cm.
    Dial signed: BREGUET N° 1150 BREVETE SGDG
    Case signed: BREGUET
    Initials PK at base of diapason.
    Finished in 1868
    The nickel-plated metal case has glass on all four sides.
    The annular dial is engraved with Roman numerals for the hours and Arabic numerals for the five minutes, with a small eccentric seconds dial in the upper part.
    The clock movement was built on the principles set down in patent n° 73414 registered on 20 October 1866 by Louis-Clément Breguet. It has two barrels, a train and an escapement. The regulating organ is a steel tuning-fork, two hundred and fifty millimetres in length and vibrating at one hundred hertz. One of its arms touches the escapement, whose function is to keep it vibrating.
    History:
    1967 (purchased).
    Finished in 1868.
    Exhibitions:
    1867, Paris
    1997, MIH, p. 33, illus.
    Bibliography:
    Comptes Rendus de l’Académie des Sciences, volume LXIII, 1866, p. 991.
    George Sire, Rapport sur l’horlogerie à l’Exposition Universelle de 1867, Paris, s.d.
    Frédéric Marle, "La pendule à diapason de Louis Breguet", Annuaire de la montre suisse, 1964, 1965.
    MIH, 1974, p. 131, illus.
    Breguet, 1997, p. 335, illus.
Name:	030a-0043 VI NOUV.jpg
ID:	39926   Click image for larger version.
Name:	030b-0337 B IV.JPG
  1. August's Object - Abraham Louis Breguet Pocket Watch
    By Noel Poirier in forum National Watch and Clock Museum
    Last Post: 08-01-2012, 07:21 AM
  2. Accutron tuning fork washers
    By MH Smith in forum Watch Repair
    Last Post: 10-25-2006, 05:49 AM
  3. Mechanical Wristwatch Omega tuning fork watch adjustment
    By Anders in forum Watch Repair
    Last Post: 02-10-2004, 02:31 AM
  4. Tuning Fork Battery Movement(s)
    By eskmill in forum Electric Horology
    Last Post: 05-01-2003, 10:16 AM
  5. Omega Tuning Fork Watches
    By Greg Davis in forum Wrist Watches
    Last Post: 02-18-2002, 02:04 PM
