Goal: $300, Received: $250.00 (84%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2746 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
Thread: pith wood
    Registered user.
    Feb 2009
    connecticut
    24
    Default pith wood
    I need to add some pith wood to my watch repair supplies but I can't find a supplier. I have tried the major houses with no luck. Am I spelling it wrong or looking in the wrong place. I have searched Esslinger, Otto Frei, and Time Zone. Can Someone Help?
    P.S. I will not drive to the Amazon.
    Default Re: pith wood (RE: db125)
    Quote Originally Posted by db125 View Post
    What you are looking for is "pithwood". It is available at Jules Borel, Esslinger, and Otto Frei or at almost any other watch material supply house. For example, Pithwood at Otto Frei. or Pithwood at Esslinger
    Registered user.
    Jun 2009
    Central Florida
    861
    Default Re: pith wood (RE: jimH)
    Cas-Ker also carries it. Cas-Ker Pithwood
    Samantha
    Apr 2002
    19,591
    Blog Entries
    Default Re: pith wood (RE: Samantha)
    Hi Samantha, the link you posted brings me to this thread.
    Registered user.
    Jun 2009
    Central Florida
    861
    Default Re: pith wood (RE: Kevin W.)
    Thank you! Sorry about that. I tried linking it again, but it did the same thing.
    Samantha
  1. Help identifying a 8 day wood works movement
    By Jim Burghart in forum Clocks General.
    Last Post: 01-22-2007, 12:19 PM
  2. count wheel for wood works clock
    By ham in forum Clock Repair
    Last Post: 02-16-2006, 05:04 AM
  3. wood ears
    By tickntock1 in forum Clocks General.
    Last Post: 11-14-2005, 06:58 AM
  4. wood with brass movement old?
    By stewart in forum Clocks General.
    Last Post: 07-28-2005, 02:01 AM
  5. Old wood screw replacements
    By Eric MacEachern in forum Clocks General.
    Last Post: 12-13-2004, 04:13 AM
