NOTICE Notice: This is an old thread. The last post was 2836 days ago. If your post is not directly related to this discussion please consider making a new thread.
    Default Adding articles to existing books
    I want to add an article to an existing book, but I cannot see any way to do it - all I can see are options to delete and sort. How is it done?
    18,622
    Exclamation Re: Adding articles to existing books (By: Richard Watkins)
    Unless I have the permissions set up wrong, you should see a book tab at the top of each article. Clicking on the tab will open the list of books with radio buttons for each book. Select the one in which you wish to include the article.
    Default Re: Adding articles to existing books (By: Tom McIntyre)
    OK, found it.
    Actually I wanted to add a book to another book. Maybe I will see if I can set up an article that redirects to a book (optimistic?
    18,622
    Lightbulb Re: Adding articles to existing books (By: Richard Watkins)
    You can use BOOK namespace references inside any article or any post on the message board. You cannot put a book inside a book. That structure is only one level deep.
    If you use the syntax [book]Name of the book[/book] there will be a reference to the book.
    You can do similar things with CATEGORY, but in that case you need to use the format [category = "CategoryName"]Words describing the category[/category]. I believe you can use that format for the book reference also, but I have not studied that.
    I have tried adding the Waltham Watch Co. book indirectly by using a redirect article set up in Tutorials. It works OK except at the moment the redirect is not automatic.
    Richard Watkins
    Books: http://watkinsr.id.au
  1. Adding weight to escapement?
    By neeerd in forum Clock Repair
    Last Post: 02-09-2011, 11:37 AM
  2. Anyone have Ehrhardt-Meggers Beginning to End book?..
    By MediaBobNY in forum American Pocket Watches
    Last Post: 06-21-2010, 03:15 PM
  3. Adding arrows and such to pics.
    By Jeff C in forum Horological Misc
    Last Post: 01-12-2007, 03:22 PM
  4. Horological tools added to NAWCC Museum website
    By Roger Huegel in forum Horological Tools
    Last Post: 05-18-2003, 05:05 AM
