NOTICE Notice: This is an old thread. The last post was 2958 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Registered user.
    Mar 2009
    Georgia
    1,215
    Default How to clamshell watch case stay closed?
    Every once in a while I will see a clamshell watch case on ebay, either the hinge is opposite the pendent or some hinge at the 8hr area and seem to swing slightly to one side. I have seen some that look like they have some type of latch anothers nothing that I could see. I suppose the ones without any latch would just snap lock, is this the case for most of the others or is there some type of pin or latch?
    Registered user. Greg Davis's Avatar
    Nov 2000
    Washington state
    2,869
    Default Re: How to clamshell watch case stay closed? (By: 49stude63)
    I presume by "clamshell" you mean a Hunting Case, the kind with the lid that covers the dial.
    These have special springs built into the case and a small latch that is attached to the spring, and is operated by pushing down on the crown. The latch makes contact with the inside of a groove in the lid when the crown is not being pressed, thereby holding the lid in the closed position.
    Over the years, that groove in the lid can tend to wear down, eventually to the point where the contact it makes with the latch is inadequate to hold the lid closed. There's not much I know of to resolve that problem. Perhaps others can offer some advice.
    - Greg
    Registered user.
    Mar 2009
    Georgia
    1,215
    Default Re: How to clamshell watch case stay closed? (By: Greg Davis)
    No I am talking about a clamshell open face case. The movement is mounted in a ring that has a pendent. You open the clamshell and you can completely remove the movement and pendent and the case is hinged and has two areas that fit around the pendent when it is closed. I have hunter watches so I know people sometimes call these "closed face" cases but this is an open face case that has two parts, when the movement is mounted the ring mount with pendent and the clamshell case that has the front and back hinged.
    Smile Re: How to clamshell watch case stay closed? (By: Greg Davis)
    I don't think that he means a hunting-case. Clamshell Cases have a bezel that "snaps" into place and a movement ring that is friction-fit, like those on Swing-Ring Cases.
    P.S. I see that we both responed at the same time. Yes, some clamshell cases have an independant movement ring, in lieu of one that hinges out.
    Kent
    That guy down in Georgia
    Registered user.
    Aug 2004
    Apache Jct AZ
    951
    Default Re: How to clamshell watch case stay closed? (By: Kent)
    I think he is talking about a pair case. such as you find on fusees cases and some early key wind American cases. If you would post picture of case we maybe of more help with your question.
  6. #6
    Default Re: How to clamshell watch case stay closed? (By: Bill B)
    Like this one ??
  7. #7
    Registered user.
    Aug 2004
    Apache Jct AZ
    951
    Default Re: How to clamshell watch case stay closed? (By: John Pavlik)
    The lip of the cover snaps on the ring that is around the other side of case that has the glass in it. When the cover is bent or the lock ring is badly worn they won't stay closed. The fix is to adjust either the cover or the locking ring. Not an easy job even with the proper tools. Hope this helps.
  8. #8
    Aug 2000
    Boston, Ma.
    17,580
    Blog Entries
    May we please have a picture and stop speculating what this is.
    I believe I know what the original poster is addressing, but would sure like to see to be sure.
  9. #9
    Registered user.
    Aug 2004
    Apache Jct AZ
    951
    Default Re: How to clamshell watch case stay closed? (By: Jon Hanson)
    Jon, pix has been up for a while now, it is a an American coin silver pair case.
  10. #10
    Smile Re: How to clamshell watch case stay closed? (By: Bill B)
    Quote Originally Posted by Bill B View Post
    Bill:
    That picture was posted by John as a question. Were still not sure what 49stude63 (the person who started this thread) is asking about.
    Kent
  11. #11
    Aug 2000
    Boston, Ma.
    17,580
    Blog Entries
    thanks, Bill B,
    The answer, I believe, without seeing it is in the catch; or..................they have been switched, or...............the crystal is incorect!
  12. #12
    Registered user.
    Mar 2009
    Georgia
    1,215
    The case that John P. posted is the type of case I am talking about. I have seen some with some type of latch but others without anything that looked like a latch so I wonder if they were snap fits like the back of most hunter cases.
  13. #13
    Aug 2000
    Boston, Ma.
    17,580
    Blog Entries
    OR button!
  14. #14
    Registered user.
    Aug 2004
    Apache Jct AZ
    951
    Try closing the pair case it self without the watch inside, to see if it closes properly.
  15. #15
    Registered user.
    Aug 2004
    Apache Jct AZ
    951
    John P nice case is it a hidden key type with the crown that unscrews?
  1. How to identify watch parts
    By Joe Werner in forum American Pocket Watches
    Last Post: 01-01-2009, 01:28 AM
  2. How to open back case on grandfathers watch?
    By william.m in forum European & Other Pocket Watches
    Last Post: 11-01-2008, 11:31 AM
  3. American Pocket Watch How to remove watch case back cover ??
    By Bill V in forum Watch Repair
    Last Post: 12-16-2006, 05:14 AM
  4. Help to polish watches cases
    By pdaneu in forum Watch Repair
    Last Post: 06-24-2006, 02:31 AM
  5. Newbie Question: How to determine watch size
    By greentruck in forum American Pocket Watches
    Last Post: 05-02-2001, 03:54 PM
