NOTICE Notice: This is an old thread. The last post was 2816 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    Registered user.
    Jun 2009
    Sioux Falls, SD
    Default Pocket Watch Snap Back Won't Stay Shut
    I just got this Elgin pocket watch with a snap back case, and no matter what I do a few seconds later after I close it, the back pops back open. Is there anything I can do to make it shut better.
    Thanks for your help
    Nick
    Default Re: Pocket Watch Snap Back Won't Stay Shut (RE: nhamze)
    It would depend on what was causing the problem. Check to see if it is a worn rim,bent part, debris, or something else that is causing the trouble. Knowing the cause will suggest a solution.
    Registered User guychampeau's Avatar
    Feb 2007
    detroit, michigan (nashville too)
    1,061
    Default Re: Pocket Watch Snap Back Won't Stay Shut (RE: Smudgy)
    sounds like a few seconds on a dapping block would do the trick
    Feb 2009
    San Jose, California
    126
    Quote Originally Posted by nhamze View Post
    Nick
    Check all screws inside the movement, sometime the case screw could on the way if not complete screw in.
    Next check inside of the back case, notice any mark left by touching parts on movement, if not, check the shape of back case by placing the case back on bench or any flat surface, push down one side, check to see the other side lift up, continue this with all corners, just make sure the back case is flat on edge.
    If still have not find any problem, check the gripping edge on inside of the back case, are all edge smotth and no dent? how about and front case? check all around the edge.
    Beyound this part will be the casemaker's skill to fix, bring to a watchmaker has casemaking experience. (Need Casemaker's tool set)
    Registered user.
    Jun 2009
    Sioux Falls, SD
    Default Re: Pocket Watch Snap Back Won't Stay Shut (RE: Genway)
    Thanks for all the suggestions, It was just a case screw as suggested by Genway, now I am good to go thanks for all the help.
    Nick
  1. Tintype Photo inside pocket watch case back
    By Jerry Bryant in forum American Pocket Watches
    Last Post: 02-18-2010, 08:18 PM
  2. Engraved Pocket Watch case backs.
    By terofpa in forum American Pocket Watches
    Last Post: 04-02-2008, 10:19 AM
  3. Replies: 3
    Last Post: 02-05-2003, 12:48 AM
  4. The Multifunction Pocket-watch is back! And in 20 years...?
    By Greg Crockett in forum American Pocket Watches
    Last Post: 02-04-2003, 04:02 PM
  5. New Hamilton Pocket Watch in BOC glass back
    By Greg Davis in forum American Pocket Watches
    Last Post: 01-19-2003, 07:57 AM
