Results 1 to 5 of 5
Thread: Friedrich Mauthe dating and info
    Default Friedrich Mauthe dating and info
    Hi All,
    I have this nice Friedrich Mauthe clock but cannot date it and don't have much info on the clock (only for the producer I found). On the back of the movement there is:
    42/ D.R.P FMS logo N 55006 16?75
    105
    D.R.P = Deutsche Reich Patent
    on the last number, in the mid it should be 6 or 7 or 8 (it is not clear at all)
    I don't know what the numbers mean, so any additional information would be apreciated (http://www.gleuenberger.com/clocks/MautheClocks.htm - you can see some info here )
    Attached Thumbnails Attached Thumbnails Friedrich Mauthe movement back-2.jpg   Friedrich Mauthe movement back.jpg   Friedrich Mauthe bell.jpg   Friedrich Mauthe-4.jpg   Friedrich Mauthe-3.jpg
    Default Re: Friedrich Mauthe dating and info
    No ideas how and where I can check the serial of this clock and find more info on it?
    I know of no existing records of Mauthe serial numbers. I think your clock is Circa 1910-1920. That's just a guess based on case style and similar clocks that I have seen. Others may have more information.
    Best,
    richard t.
    Feb 2009
    6,580
    germany  european union
    NAWCC
    The style of the case is called "Gründerzeit", a period starting about 1875 and lasting untill about 1900.
    Free swingers of this type were built untill approx. late 1920s though, so dating isn't very easy.
    Going by the dial (is there a "T" in gear wheel there?), I would presume the
    clock is +/- 1900.
    There is a museum in Germany however, that may give you some information.
    Here's the address:
    Museum und Archiv Mauthe
    Neckarstr. 3
    78056 Villingen-Schwenningen
    Jurgen
    Sep 2000
    The Woodlands, TX
    7,035
    usa  us texas
    NAWCC
    Quote Originally Posted by rejo View Post
    Hi All,
    105
    D.R.P = Deutsche Reich Patent. On the last number, in the mid it should be 6 or 7 or 8 (it is not clear at all)
    Rejo, to my knowledge there has not been any information published that would relate Mauthe serial numbers to a manufacturing date. Perhaps someone will undertake the research to develop this, the main thing is to be very methodical and record the main features of both the movements and cases.
    The patent number DRP 55006 refers to a pendulum leader that prevents excessive overswing and thus protects the pallets and escape teeth from damage. This patent was granted 24 January 1891 with protection back to 18 March 1890. See the patent scan attached, your clock doesn't have this feature but having the patent stamp on all similar movements would enable them to use it as they wish.
    The next number (16?75) is not a relevant DRP patent number, thus it may be the serial number of the clock. Without having a database for these, however, it isn't possible to determine a date.
  1. Caledon London, Chain drive, fuzie with verge escapemant. Looking for date and info
    By Larry Krayer in forum European & Other Pocket Watches
    Last Post: 09-17-2012, 04:06 PM
  2. Alright Guys help with dating and info on the company
    By Timothy Davis in forum American Pocket Watches
    Last Post: 03-23-2011, 08:30 PM
  3. Bulova watch - date and info wanted.
    By r0n1n in forum Wrist Watches
    Last Post: 06-30-2010, 11:49 AM
  4. Replies: 23
    Last Post: 01-19-2010, 05:43 PM
  5. info about ansonia date and front pane
    By suvro in forum Clocks General.
    Last Post: 08-16-2007, 12:38 AM
