Goal: $300, Received: $100.00 (33%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2850 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Default strange hampden watch
    I have an old Hampden watch (at least thats what it says on the face) but the serial number on the movement is much earlier than Hampden made. I have seen plenty of discussions around putting Hampden movements into a case with a NY Watch face but not the other way around.
    My serial is 24106 and the movement has "Chester Woolworth" "Springfield Mass" and "Adjusted" engraved on it.
    It is a key wound and key set watch in a coin silver case.
    Would anyone have any insight as to exactly what I have?
    Technical Admin Tom McIntyre's Avatar
    Aug 2000
    Boston. MA USA
    18,486
    Blog Entries
    10
    Lightbulb Re: strange hampden watch (RE: dougmc)
    There was quite a bit of material left from New York Watch Co. when Hampden showed up. It is not uncommon to find Hampden dials on New York movements and that is what it seems you have.
    Default Re: strange hampden watch (RE: Tom McIntyre)
    Thanks, that's what I sort of figured.
    Given the serial number I would guess the movement about 1871 or so based upon this http://www.pocketwatchsite.com/newyorkserials.html. And the assembly around 1877.
    Default Re: strange hampden watch (RE: dougmc)
    If the movement is from the New York Watch Co. would the movement say Springfield Mass?
    Aug 2000
    Boston. MA USA
    18,486
    Blog Entries
    10
    Quote Originally Posted by dougmc View Post
    Dueber operated the Hampden Watch Co. in Springfield for a while before moving. There is an article in the Wiki area called Dueber-hampden watches, 1886. It tells the story of shopping for a place to put the combined watch and watch case factory.
    A watch that says Hampden Springfield would almost certainly have been made after the purchase but before the move.
    The serial numbers are meaningless for these watches with fires and recessions, there is almost no correlation between sn and date. Hampden finished a lot of leftover material and in some cases seems to have re-engraved it.
  6. #6
    I bought a watch from an Ebay auction that was wearing a Hampden dial. It turned out to be a New York Watch co 18s 15j key wind, adjusted. Its signed "Woolworth" only, but the gent that serviced it assures me its the real deal. It's also an excellent timepiece now, needing only minor attention and the correct dial. Rather an enjoyable experience, but I'd rather not go thru it again. I doubt there are that many clean dials available.
  7. #7
    Default Re: strange hampden watch (RE: Bratdaddy@mac.com)
    Quote Originally Posted by Bratdaddy@mac.com View Post
    Serial number?
  1. Hampden Watch Co. Circa 1894-95 Value?
    By Watchkollektor in forum American Pocket Watches
    Last Post: 02-22-2006, 10:05 AM
  2. American Pocket Watch Hampden watch repair in Houston
    By Wes in forum Watch Repair
    Last Post: 10-06-2005, 04:31 AM
  3. Hampden watch particulars
    By RL in forum American Pocket Watches
    Last Post: 07-11-2005, 07:42 AM
  4. Strange Howard watch serial no
    By Dave Berghold in forum American Pocket Watches
    Last Post: 03-24-2005, 02:00 AM
  5. Information Requested on Dueber-Hampden Watch
    By Kenny D in forum American Pocket Watches
    Last Post: 06-23-2004, 01:28 PM
