Results 1 to 2 of 2
Thread: Oiling pivots before reassembly
  1. Default Oiling pivots before reassembly
    Dennis,
    This is not really necessary except in the case of pivots that cannot be reached after assembly. An example would be the lower pivot of the minute wheel in a French clock. Capillary attraction will distribute oil around the pivot when it is oiled from the outside of the bearing. This can be sped up a little by flexing the end-play of wheels after the pivot is oiled.
    You should be more concerned that you not over oil a pivot. If there is too much oil in a bearing, it might pool and all the oil runs down the plate leaving a dry bearing. Jcl
    John C. Losch
    Holliston, Mass.
    Aug 2000
    Calgary, Alberta
    10,134
    canada  ca alberta
    NAWCC
    Dennis,
    John makes several good points. But I would also add that you are likely to spoil your oil job if you were subsequently obliged to take the clock to pieces for an adjustment. Depending on the clock, things like the clutch (cannon pinion) on the center wheel of a German clock, or the minute pinion (center) shaft clutch on an American clock should be lubed while apart. Springs as well. The rest of it should be oiled when you know you are finished with the repair.
    Doug
  1. How to oil pivots
    By Sobie-one-canobie in forum Clock Repair
    Last Post: 12-04-2011, 12:26 PM
  2. Replies: 9
    Last Post: 03-01-2008, 10:01 AM
  3. What To Use To Apply Oil To Pivots?
    By popeye in forum Clock Repair
    Last Post: 02-04-2007, 02:38 AM
  4. SHOULD JEWELLED PIVOTS BE OILED ??
    By Bill V in forum Watch Repair
    Last Post: 01-03-2007, 01:05 PM
  5. type of oil to use when burnishing pivots
    By alskogen in forum Clock Repair
    Last Post: 10-10-2005, 10:59 AM
