Goal: $300, Received: $250.00 (84%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2849 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 11 of 11
    Default Level Grandfather Clock
    Is it imperative a Grandfather Cabinet be fully level front to back and side to side? I have seen many variations and all seem to work. Some advocate the case be leaning towards the wall.
    thanks
    tick
    Default Re: Level Grandfather Clock (RE: ticktock)
    As well as being level, front to back and side to side, also what is highly important is that it is stable, and does not rock in any way, especially when winding or pulling the chains. What I mean by rocking, is by applying a rocking motion from the front left corner to right rear corner, or diagonally, and vice versa to the opposite side. It eliminates sympathetic vibration and the pendulum or weights knocking into each other, and this especially on narrow-waisted clocks.
    Must you spend time getting it absolutely perfect? No. I go by "reasonably level", and that it is stable as described above. Leaning the case back can cause interference with the pendulum and chime rods. And remember this; no two walls will be perfectly at right angles with each other, or the floor. I have pushed the base of a grandfather till both rear corners touch the baseboard, and the top of the case has 'gap-osis' on one side or the other. So, to me, stability is the most important after leveling. My two bits worth....................doc
    Exodus 31:6 "...and I have given to all able men ability, that they may make all that I have commanded you."
    Default Re: Level Grandfather Clock (RE: doc_fields)
    You can usually work around unlevel. You can't usually work around unstable. Personally, I'd prefer leaning to bolting to the wall (unless there's already a hole in the case). A slight lean against a spacer is workable too. As mentioned, you can't have interference with the pendulum or chains (cables) and grossly uneven swing (in relation to the case) is quite noticeable and undesirable. But the case must be stable - whatever it takes.
    So we're at four bits .... any others?
    Registered user.
    Jun 2008
    Westminster. MD
    2,390
    Default Re: Level Grandfather Clock (RE: shutterbug)
    Ninety percent of the older tall clock cases I have run across had a hole somwhere in the back that I could either screw to a block, which was mounted to the wall, or go directly through into the wall. I always recommend this on those narrow-waisted tall clocks with the really heavy weights. They are just too top heavy when fully wound.
    Default Re: Level Grandfather Clock (RE: Dave B)
    Many tall case clocks (especially the newer ones) have leveling feet installed.
    If that is the case--leveling and proper tilt becomes a fairly easy set up!
  6. #6
    Registered user.
    Sep 2008
    Irish, but live in Laprade, 16390, France, (70 miles east of Bordeaux)
    3,240
    Default Re: Level Grandfather Clock (RE: burnz)
    it isn't crucial if a longcase leans back, but the following can happen
    the pendulum suspension block can be touching the outer end of the crutch loup/fork. this is a problem if the fork is not open ended.
    the pendulum bob can catch the back of the cabinet
    or can touch the chime rods if there any.
  7. #7
    Registered User Scottie-TX's Avatar
    Apr 2004
    Mesquite, TX
    938
    Default Re: Level Grandfather Clock (RE: laprade)
    Level shouldn't matter, long as it's in beat and it can be unlevel, in beat.
  8. #8
    Registered user.
    Dec 2003
    West Yorkshire, England
    9,813
    Default Re: Level Grandfather Clock (RE: Scottie-TX)
    Yesss! What will stop it, is a carpet, and the clock not screwed to the wall.
    Mike - banned member of the throwaway society. :o
  9. #9
    Registered user.
    Sep 2008
    3,240
    Default Re: Level Grandfather Clock (RE: Mike Phelan)
    in one of the posts I saw some mention of a two legged grandfather.
    Very often people would remove the rear support to make room for a skirting board.
    in Speke Hall, Merseyside, UK, (one of the UK's finest Tudour Black and white buildings), there is a brass faced clock standing at the foot of a back-stairs (for servants) the clock has a cut-out to allow it to stand half on the bottom step.
    up till the 80s, the average longcase clock was worthless, unless it was a famous name. An engraver told me that the Lewises department (part of Selfridges group) store in Liverpool, had a workshop on his street, where they had two cabinet makers turning the 'trunks' into coctail cabinets. the movements went to the local scrap yard. the hoods were burnt in the workshop fire.
    the first grandfather clock I had in my shop was given to me by another dealer. He didn't want it cluttering up his shop!
  10. #10
    Sounds very strange?
  11. #11
    Registered user.
    Dec 2003
    9,813
    Default Re: Level Grandfather Clock (RE: clockdoc45)
    Quote Originally Posted by clockdoc45 View Post
    Er, what does, Doc? The clocks with no feet on the back, pieces being removed, or the supposed prices?
    Not uncommon at all, but they were made like that, as if you think about it, they are not necessary.
    I've never seen one like that, and have to wonder why they don't just put some sort of spacer the same thickness as the skirting, betwixt the wall and the case, like I have done on mine.
    in Speke Hall, Merseyside, UK, (one of the UK's finest Tudor Black and white buildings), there is a brass faced clock standing at the foot of a back-stairs (for servants) the clock has a cut-out to allow it to stand half on the bottom step.
    Never been there myself, but, ugh! Butchery!
    Depending whom you term as a famous name; I would say these are probably less then 1% of the LC clocks from 1680-1880 anyone here in UK would own, excepting collections in museums and the like.
    As for them being worthless, not true at all! In 1980, brass dial LCs prices cost anything from £500 - £5000, if complete; painted dial ones about half that. I repaired many for a friend in the process of teaching him to make it a business, and bought his clocks at dealers and auctions, and know what sort of prices they fetched. In many cases, more than they do now.
    He's either telling porkies or his memories are flawed! Lewis never had a clock workshop, and no-one would be silly enough to scrap a movement of value; if they did, the scrap dealer would make a fortune. Neither would any cabinet maker burn any old pieces of hardwood.
    I'd be sitting outside the back of his shop, for one!
    That said, if you replace "80s" with "20s" you would be right about most of this!
  1. Grandfather Clock Leveling
    By ticktock in forum Clock Repair
    Last Post: 04-30-2007, 05:59 AM
  2. Previous Info on Grandfather Clock ID Request.
    By Paul Lopez in forum Clocks General.
    Last Post: 09-19-2006, 03:11 AM
  3. Grandfather clock stopping
    By Steve G in forum Clock Repair
    Last Post: 01-17-2006, 02:36 PM
  4. Colonial Zeeland grandfather clock Chimes
    By Scottie-TX in forum Clock Repair
    Last Post: 11-13-2005, 08:01 PM
  5. Grandfather Clock
    By apjarvis in forum Clock Repair
    Last Post: 11-21-2004, 07:12 AM
