Goal: $300, Received: $100.00 (33%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2919 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Default Seiko quartz replacement movement
    Anyone know where I could find a Dual chime quartz movement for a Seiko mantel clock ? I have checked all the bigger clock supply sites ! I believe this 1 would fit the "mini" catagory ? As it measures approx. 2.75 wide x 2.75 high x about 9/16th deep,, it mounts onto a plate behind the dial.. If nothing else,, I guess I could take the time to make a new mounting plate and pillars,, but don't know if I want to spend THAT much time on a non winding clock,, that was basically given to me !! Look forward to any ideas.
    Take care !!
    Default Re: Seiko quartz replacement movement (RE: labzman)
    Try this
    Default Re: Seiko quartz replacement movement (RE: shutterbug)
    Shutterbug,,,,Yes I have seen those on that site,, but,, it is to wide !!
    Unless,,, I could spin the movement 180 degree's ? Not sure if that would work or not
    Thanks,, later
    Quote Originally Posted by labzman View Post
    Thanks,, later
    As long as it's not a chiming or striking clock, it won't care how it's mounted
  1. Electrical Wristwatch replacement movement for quartz
    By FredWJensen in forum Watch Repair
    Last Post: 07-14-2010, 07:05 PM
  2. Seiko quartz movement
    By psperber in forum Clock Repair
    Last Post: 06-12-2009, 05:25 PM
  3. Seiko quartz movement
    By Jim Myers in forum Clock Repair
    Last Post: 12-02-2006, 02:44 AM
  4. Hamilton Quartz 955 Movement
    By harold in forum Wrist Watches
    Last Post: 10-19-2006, 05:01 AM
  5. Replacing movement in old slave clock
    By Hesperian in forum Clock Repair
    Last Post: 08-26-2005, 07:25 AM
