Goal: $300, Received: $370.00 (124%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2466 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Thumbs up BOOKREVIEW: Heskin: Sleeping in Oblivion [Harrison's RAS Precision Clock]
    BOOK REVIEW
    The final masterpiece of John Harrison
    Sleeping in Oblivion, John Longitude Harrisons Forgotten Masterpiece, by David Heskin. Second edition, published 2008 by Soptera Publications, Loughborough, Leicestershire, (soptera@tiscali.co.uk <mailto:soptera@tiscali.co.uk>); hardback, 201 pages, 20x27 cm; ISBN 978-0-9555875-2-8 (hand bound hard back) and 978-0-9555875-1-1 (comb bound paperback), 95 figures (b&w photographs) and 8 section frontispieces (white on grey design studies). (Text in English). Index, Terminology (Glossary) and Abbreviation List. Available from Soptera Publications. (Text in English). Index, Terminology (Glossary) and Abbreviation List. Available from Soptera publishers Current prices at http://soptera.blogspot.com., or consult at the Library & Research Center at the National Watch & Clock Museum. (The author has restricted the lending of the copy for fear the lender will make photocopies)
    Even the casual timekeeping enthusiast will be familiar with John Harrisons great achievement in winning the Longitude prize by increasing the sustained performance of seagoing clocks sufficently to allow accurate longitudinal navigation at sea. Far fewer realize that Harrisons success was due to meticulous, systematic and scholarly work on various issues affecting the accuracy of timekeepers, work he continued for many years after building his prizewinning marine chronometer H4 around 1757. But hardly anybody knows that, in the final phases of his life, John Harrison published in 1775 - a year before his death a manuscript called Concerning Such Mechanisms as will Afford a Nice, or True Measurement of Time, & summarizing the work of and horological insights gathered over an entire lifetime. The text repeatedly refers to a precision longcase regulator Harrison was building at the time, and which would incorporate all of Harrisons ideas, and which he expected to be accurate to better than one second in 100 days. Sadly that clock was never completed by Harrison. Its final Harrisonian state was never fully documented, and the clock was only completed in the 1920s by Rupert Gould. That clock is known as the Royal Astronomical Society Clock (after its owner). Both the 1775 text and the RAS clock have since then been mostly sleeping in oblivion, a term used by Harrison himself when writing about what he hoped to avoid for the future of his discoveries.
    The author of the book under review, David Heskin, is convinced that a thorough study of  and experimentation with the design of  the RAS clock, combined with a careful reading of the Harrison text will provide new knowledge of Harrisons understanding of precision horology. As a step in that process he set out on the arduous journey to build a functional replica of the RAS clock. That task was greatly complicated by the fact that the RAS clock has never been fully documented, and Heskin was never allowed to physically examine or handle it, let alone disassemble the movement. The movement was on display in a glass show case in Greenwich, and the author -starting in 2002-painstakingly recorded it through pencil and paper sketches as photography was not allowed.
    The book is a detailed description and documentation of the functional replica of the RAS clock as built by Heskin at the beginning of the 21st century. The author, of course, realizes that his publication, due to the handicaps imposed by the way it came into being, falls far short of the desired ideal outcome, a detailed and dimensioned technical documentation of the actual, historic RAS clock movement (as completed by Gould). But Heskin is convinced that his approach is a viable first step in the process of rescuing Harrisons horological insights imbedded into the RAS movement from being forever lost in oblivion. He expresses the hope that other clock builders will use his data to build other functional replicas of Harrisons Final Regulator.
    The book itself makes for fascinating reading for the small target audience of technically inclined Harrison fans. While the ultimate purpose presumably is to describe in great detail how the RAS movement and its grasshopper escapement works, in practicality it reads more like a step by step, how to guide for building and assembling a replica movement. The core of the book, its largest section, labeled Detailed Pictorial, consists of 83 pages, each made up of one or several detailed black and white photographs of parts, components and subassemblies and the complete movements. Many of these are like de-facto dimensioned drawings and manufacturing instructions of the various parts, but also a series of a dozen close-up photos showing the operating sequence of Harrisons design for the grasshopper escapement of the RAS clock.
    Heskin had to make many choices along the way to define his concept of a functional equivalent replica. While he meticulously maintained the overall geometry of Harrisons design, and used pairs of large anti-friction wheels for the pivots in the gear train and self lubricating lignum vitae components in some places, he used mostly modern standard metric screws and industrial ball bearings for the great arbor and the weight pulleys, arguing that Harrison would have used these components had they been available in his time. The resulting movement is a curious hybrid of traditional and modern elements, and this reviewer found it hard to judge definitively how closely the performance of the resulting mechanism would match Harrisons original ideas.
    Since the time that Heskin started building his functional replica and wrote his book, the owners of the original Harrison clock have allowed a scholar to actually disassemble and measure the clock and it appears that the dimensions that Heskins had determined based on his sketches and observations, as well as from various published sources, are amazingly close to correct. Rumor has it that currently there are two other parties in the early phases of building replicas of the RAS clock. So we may soon find out if Harrisons performance claims of one second in 100days are factual. (The Heskin book was written before the author had any long term performance data from his clock).
    Other sections of this book cover: Principles of Precision, talking about concepts such as the gridiron compensating pendulum or the escapement action; Construction; Assembly; Operations, outlining some practical issues about running the resulting timekeeper.
    While reading even in great detail- about an important clock movement can never fully replicate the experience of handling, playing-with and experimenting with an unusual or historically significant clock movement, this reviewer found the process of studying the RAS movement in this text and image format surprisingly satisfying, and an obvious alternative for learning quite a lot about an artifact whose custodians would never let us examine it physically.
    Despite the obvious limitations of his functional replica approach to truly replicate any original, Heskin deserves the gratitude of Harrison scholars around the world for doing his share of rescuing key facets of Harrisons longcase precision movement design knowhow out of oblivion by not only building his replica, but for making its construction details accessible through this book to a wider audience.
    Fortunat Mueller-Maerki
    Sussex, New Jersey
    February 22, 2009
    Last edited by Fortunat Mueller-Maerki; 08-27-2009 at 06:09 AM. Reason: corrected price and publisher information
    Fortunat Mueller-Maerki, -Chair NAWCC Library Com./ Editor & Publisher of BHM
    Mem.NAWCC Mus.Coll.Com. / VP, USA Sect. Antiq.Horolog.Soc.
    Default Re: REVIEW: Heskin: Sleeping in Oblivion [Harrison's RAS Precision Clock] (By: Fortunat Mueller-Maerki)
    _Another_ spendy technical horology book!
    Just a few notes I gathered while looking further:
    You can get more info on ordering from:
    http://soptera.blogspot.com/
    In case you are looking at other internet listing for a
    better deal, I have collected some info on editions vs.
    ISBN numbers (from amazon.co.uk):
    ---------- First edition
    Paperback: 209 pages
    Publisher: Soptera Publications; 2 edition (1 Jun 2009)
    Language English
    ISBN-10: 0955587530
    ISBN-13: 978-0955587535
    Hardcover: 210 pages
    Publisher: Soptera Publications; First Edition edition (1 Jul 2007)
    Language English
    ISBN-10: 0955587506
    ISBN-13: 978-0955587504
    ---------- Second edition
    Spiral-bound: 211 pages
    Publisher: Soptera Publications; 2nd Revised edition edition (19 Dec 2008)
    Language English
    ISBN-10: 0955587514
    ISBN-13: 978-0955587511
    Hardcover: 209 pages
    Publisher: Soptera Publications (19 Dec 2008) [Assume this is the second edition]
    Language English
    ISBN-10: 0955587522
    ISBN-13: 978-0955587528
    Default Re: REVIEW: Heskin: Sleeping in Oblivion [Harrison's RAS Precision Clock] (By: beorn)
    Thank you beorn for posting the references to the earlier and cheaper editions.
    Indeed it is a relatively pricey book and it pays to hunt for used copies at better prices.
    Registered User PowerClocks's Avatar
    Apr 2004
    Sydney Australia
    46
    Default Re: BOOKREVIEW: Heskin: Sleeping in Oblivion [Harrison's RAS Precision Clock] (By: Fortunat Mueller-Maerki)
    Hi, I have been looking up most available information on the Harrison Regulator and notice you mention some Scholars were recently given access to the clock, are you able to name the Scholars who did the examination? has there been any material either in publication or about to be published from them on this important clock to assist in a more faithful replication or test of the movement. Whilst the book Sleeping In Oblivion goes a long way towards satisfying my curiosity I would like to perhaps add an appendix to it with the 100% correct information obtained first hand by the Scholars. Whilst I am given to understand the variations were negligible any variation to me is not completely acceptable. Should you wish to write to me direct please use the following e-mail address, your time to reply is appreciated. Graeme Power adtvenquiries@hotmail.com
  1. Help in ID'ing a Kienzle Wall Clock
    By John Sims in forum Clocks General.
    Last Post: 12-25-2009, 07:51 PM
  2. Help in identifying Medaille D'argent 1855 Clock
    By rs1916 in forum Clocks General.
    Last Post: 09-16-2009, 03:56 AM
  3. BOOKREVIEW : Betts -Time Restored: The Harrison timekeepers and R.T. Gould..
    By Fortunat Mueller-Maerki in forum Horological Books
    Last Post: 12-31-2006, 12:34 AM
  4. BOOKREVIEW: Huygens Legacy The Golden Age of the Pendulum Clock
    Last Post: 12-10-2004, 08:21 AM
  5. Help in dating a New Haven Austel Clock
    By Ed Cypress in forum Clocks General.
    Last Post: 02-08-2003, 07:31 AM
