NOTICE Notice: This is an old thread. The last post was 2999 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 2 of 2
    Default Telechron replacement motor
    Good day all. I think there is a 1rpm replacement motor for the old synchronous Telechron motors. I have a Revere clock with a 1 rpm Type B2 motor. The rotor seems to have a stripped spot on a gear. It runs for a bit then the drive gear won't. If I turn the drive gear by hand, then it runs a bit more then stops. All the while I can hear the rotor running.
    Info on locating the replacement single piece motor and whether it will fit my clock will be appreciated.
    Info on repair of the rotor will also be appreciated.
    Dan
    Default Re: Telechron replacement motor (By: dan0661)
    Dan,
    Check out my reply to "Revere Help" in this forum just minutes ago. This will give you two sources for rebuilt rotors.
    I hope this helps you.
    Good luck!
    Bill
  1. Haddon Golden Vision Replacement Motor
    By steve102 in forum Electric Horology
    Last Post: 05-10-2014, 01:54 PM
  2. Pam Clock (Advertising) Replacement Motors?
    By joypebble in forum Electric Horology
    Last Post: 05-22-2009, 01:07 PM
  3. Need replacement motor
    By bangster in forum Electric Horology
    Last Post: 11-22-2005, 03:16 AM
  4. Telechron B2 motor
    By glr1109 in forum Electric Horology
    Last Post: 02-27-2005, 11:26 AM
  5. Wanted: Coil for Warren Telechron B2 motor
    By Mike Phelan in forum Electric Horology
    Last Post: 12-31-2003, 05:30 AM
