Goal: $300, Received: $40.00 (13%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3004 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    Question What size crystal do I need for this Elgin?
    I recently purchased an Elgin pocket watch, serial number 17174446 but the crystal is missing. I have already been able to get the watch running well but am having a problem establishing the crystal size I need to order for this watch. And in case this additional info is of help on this question, the case itself says "warranted; B & B Royal; 20 years; 6619471". Thank you for any assistance.
    Aug 2000
    Boston, Ma.
    17,580
    Blog Entries
    Default Re: What size crystal do I need for this Elgin?
    to measure it yourself, you will need to get a crystal gauge
    Smile Re: What size crystal do I need for this Elgin?
    Hi roosterscn:
    Welcome to the NAWCC American Pocket Watch Message Board!
    Crystal sizes are independent of movement sizes, except that cases of a given movement size will require crystals within a certain range of diameters. Always keep in mind that all cases made for the same size movement do not use the same crystal size. Also, the ranges of crystal diameters that might be needed for successive movement sizes will overlap.
    A caliper, reading in thousandths (1/1000's) of an inch, or tenths (1/10's) of a millimeter, is needed to measure a bezel to determine the correctly-sized crystal. Bezels have slightly larger diameters inside the "bottom" of their groove, than inside their upper rim. To find the correct crystal size, one needs to measure that larger inside diameter. This is because the correctly-sized crystal is held in place by the upper rim, such that cement is not needed for a correctly-sized crystal. It simply 'snaps' into place.
    Then, depending upon whether the measurement is in inches or millimeters, use the appropriate chart to find the right crystal size. Or, crystal suppliers ought to be able to furnish a correctly-sized crystal directly from your measurement. Depending upon the cost of the crystals, it might be advisable to get one or two sizes immediately larger and smaller than the one indicated by the measurement, especially if expect to continue collecting the same size watches.
    A crystal size chart, and its explanation, can be viewed at:
    http://www.elginwatches.org/scans/mi...7/m_index.html
    To view, go to the Elgin Watch Collectors Site Home Page at elginwatches.org, then copy and paste the address in your browser's address bar and click on 'Go'.
    Thanks to Steve Maddox, we have access to a Crystal Size to Decimal Inch Conversion Chart.
    Good luck,
    Kent
    That guy down in Georgia
    Aug 2000
    Boston, Ma.
    17,580
    Blog Entries
    Default the correct, quick answer to do the job...................
    The fullproof way is to have a filled crystal cabinet, clean out the bezel groove, and find the correct one to snap in.
    You can also contact William White at info@whitescrystals.com for a new glass crystal that he makes. The best thing would be to send the bezel to him to be fitted.
  1. Replies: 3
    Last Post: 08-06-2012, 06:23 PM
  2. What crystal do I need for a 1969 Bulova Accutron 218
    By cjaccardi in forum Watch Repair
    Last Post: 06-22-2012, 07:43 AM
  3. What do I need for this clock?
    By Mike306p/Ansoniaman in forum Electric Horology
    Last Post: 09-11-2009, 12:54 PM
  4. What movement do I need for this Porcelain case
    By anetro in forum Clock Repair
    Last Post: 04-25-2008, 08:27 PM
  5. What size mainspring do I need? Who were Rowe Bros?
    By doug sinclair in forum Watch Repair
    Last Post: 09-25-2004, 02:18 AM
