Goal: $300, Received: $40.00 (13%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2434 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: beat amplifier
    Registered user. CORKPJ's Avatar
    Oct 2008
    Newcastle, NSW
    23
    Default beat amplifier
    I needed a beat amplifier for a 400 day clock repair. A small stick FM radio receiver has all the requirements, but needs slight modification.
    Open the case and remove the pickup coil and associated diode.(the bits with wax on them). Make room for the 3.2m/m socket connection for the piezo diaphragm input, if there is none. Connect the centre connection of the piezo diaphragm to the base input of the transistors that drive the headphones. The other connection to the battery negative. The piezo diaphragm can be hung or clipped to the movement just about anywhere. Its very sensative. The better the quality of earphones, the better the sound.image shows the setup. Its easy to construct and very useful.
    May 2003
    Philadelphia
    819
    Thumbs up Re: beat amplifier (RE: CORKPJ)
    That's what I would call " Aussie ingenuity". Well done.
    leghorn
    Registered User Scottie-TX's Avatar
    Apr 2004
    Mesquite, TX
    938
    Default Re: beat amplifier (RE: leghorn)
    I made mine using an electret mike element and inexpensive 9V. mini amp and alligator clip.
    Default Re: beat amplifier (RE: CORKPJ)
    I feel kind of silly in giving this information out since almost everyone here knows more about clock repair than I do. I wanted a beat amplifier because my shop is in the basement along with the laundry, etc. The noise made it difficult to hear the beat of clocks. I picked up a mechanics stethoscope at Harbor Freight for a special price of $1.99. I can hear every tick and tock and all the other little noises clocks make.
    Dave
    Nov 2002
    38,858
    Default Re: beat amplifier (RE: Dave D)
    Dave, I also use a mechanic's stethoscope. Works for me
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  6. #6
    Registered user.
    Jan 2007
    Maryland
    466
    Default Re: beat amplifier (RE: Scottie-TX)
    Quote Originally Posted by Scottie-TX View Post
    Scottie: The pickup for amplifier I bought from Time Savers died. Can you tell me where you bought the element you have? Thanks...Paul
  7. #7
    Apr 2004
    Mesquite, TX
    938
    Default Re: beat amplifier (RE: Paul Arsenault)
    I do note that TIME$AVERS does sell the pickup a$$embly alone but asks a ridiculous $21. for it. Check yours out or if you know a friend who does electronics - have him do it. In all probability, a wire is simply broken either at the plug end or pickup end - more likely broken at the plug end. However I bought my electret mike element from Radio Shack for a few bucks.
  8. #8
    Quote Originally Posted by CORKPJ View Post
    Howzabout more pics, and maybe a diagram, for us electronically ingnernt folks?
    bangster
  9. #9
    Registered user.
    Jan 2007
    Maryland
    466
    Default Re: beat amplifier (RE: bangster)
    I bought a piezo transducer from Radio Shack for $1.99, soldered it to the jack to the amplifier and it works perfect. In fact it's alot more sensitive than the original unit.
  10. #10
    Quote Originally Posted by Paul Arsenault View Post
    Yeah, but Cork's unit starts out life as an fm radio, and those don't normally come with input jacks to plug the piezo into. That's why he does some modifications to get the input. He says:
    "... remove the pickup coil and associated diode.(the bits with wax on them). Make room for the 3.2m/m socket connection for the piezo diaphragm input, if there is none. Connect the centre connection of the piezo diaphragm to the base input of the transistors that drive the headphones. The other connection to the battery negative."
    Without further guidance, I won't know a pickup coil & diode from a watermelon; and I don't know enough about transistors to tell which is the base input. But with just a LITTLE more of the right info, I think I could follow the instructions.
    bangster
  11. #11
    Apr 2004
    Mesquite, TX
    938
    Well, I also was trying to suss it out. I gather that he inserted his pickup at the audio preamp input. Since it has no speaker, it also has no power amplifier, so this beat amp will require an ear bud or similar. Not sure about the "pickup" he removed, nor the diode. Possibly the "pickup" was the second interstage transformer. Perhaps the diode was it's second detector. If I were doing this, I'd probably choose a cheap radio that does have a power amp and speaker. Then no headgear is required.
    As for P/Us and diodes vis a vis watermelons - you'll notice the diffrunts right away. Watermelons are juicier. Diodes are hard to chew and coils get stuck between yer teeth, plus neither have pits to launch.
  12. #12
    Registered user.
    Jan 2007
    Maryland
    466
    Scottie: If you have a stereo with a low level input you can plug the Radio Shack pickup directly into it and it works fine. No seeds no juice and no mess. Paul
  13. #13
    Apr 2004
    Mesquite, TX
    938
    Oh, I understand that, PAUL. A phono input would work just fine because it has a pre-pre amp. Might be a tad inconvenient, wheeling a forty pound McIntosh pre amp and sixty pound, HH Scott power amp around for beet testing tho. But yeah; Understand. Me an' BONG wuz jes figgerin' out what CORKY had goin' on there.
  14. #14
    Registered user.
    Jan 2007
    Maryland
    466
    Scottie: HH Scott, Maynard Mass. In it day that was good stuff. Now that is some vintage equipment. Is it one of the tube type? Brings back memories. Paul
  15. #15
    Apr 2004
    Mesquite, TX
    938
    Mc is C32 - top of line ca. 1975. HH Scott top of the line LK 150 laboratory series Ca. 1958. Now running four, KT88s. These wake up a pair of Altec Mod 19s - home version A7 VOTs with 21" horns I added.
    Whatta beat amplifier!
  1. Beat Amplifier Help, Please
    By jh225 in forum Horological Tools
    Last Post: 08-01-2009, 08:44 PM
  2. Beat Amplifier
    By PLAYMOOSE in forum Horological Tools
    Last Post: 12-27-2007, 10:03 PM
  3. Beat Amplifier
    By kenknox in forum Horological Tools
    Last Post: 08-23-2007, 10:56 AM
  4. Beat Amplifier
    By Jerry1234 in forum Clock Repair
    Last Post: 11-01-2006, 04:52 AM
  5. Beat Amplifiers
    By Jerry1234 in forum American Pocket Watches
    Last Post: 10-31-2006, 03:46 PM
