Goal: $300, Received: $115.00 (38%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3278 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
Thread: plymouth clock
    Default plymouth clock
    Hi: all you clock people: a old man 76 brought me an old clock that he said his mother got for a wedding present. on the dial it says PLYMOUTH, made in USA. the label on the back door. directions covering clocks #4300, 4500 and 4600 series 8 day in tambbur cases. at the botton it has :the plymouth clock co. thomaston conn. on the movment it has 4503 and 3-39. the pendulum is heavy like a seth thomas. put there is no mention of ST any where on the clock. it strikes on two chime rods. all pivot holes are bronze bushings. any place a E ring is used it has a conpression ring. the verge is simular to a pin verge. the pallets look like a square pin that has been mashed. the escape wheel has pointed teeth perpendicular to the wheel rim. the main springs are 11/16 x .018 x 72" long. no one lists a 72" spring for this size. what have I got?. was there a plymouth clock co?. any information or dates would be greatly appreciated. all, have a good day. thanks moe
    Default Re: plymouth clock (By: moe schmidt)
    Hi moe,
    Your Plymouth clock co. tambour is dated 3 39 (March 1939). I don't remember exactly but that is after Seth Thomas became a division of General Time in 1931. Quite often the stories/history that comes with a clock is incorrect.
    Best Regards,
    Richard T.
    Best,
    Richard T.
    The Plymouth Clock Co. was a division of the Seth Thomas Clock Co. formed ca. the mid 1930's, I believe. It made a line of less expensive clocks, many of which were tambours. They made at least one banjo, a GW/Mt. vernon model similar to those put out in the ST name.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
    Moe,
    The Plymoth brand was used to unload or dump more clocks into a very depressed economy without ruffeling the feathers of the dealers who had contracted to sell the Seth Thomas brand. Something like the Toyota and Yaris brands of today.
    You have a General Time movement but earlier Plymoths had the bread and butter Seth Thomas #89 movement until the S-T company sold out in 1931 (I believe it was) and all of the old style mvts were used up
    Was always wondering about the point of plymouth clocks. Thank you.
  6. #6
    thanks to all: I now know what he has. very interesting information. all have a good day moe
  1. Correct pendulum for a Plymouth clock?
    By Schmeltzer in forum Clock Repair
    Last Post: 01-25-2007, 11:01 AM
  2. Plymouth Clock
    By walshja in forum Clocks General.
    Last Post: 11-28-2006, 09:49 AM
  3. Plymouth Clock Company Thomaston Conn.
    By Donna Favero in forum Clocks General.
    Last Post: 11-30-2003, 09:03 AM
  4. INFO:Plymouth CLock Co TAMBOUR CLOCK
    By time4now in forum Clocks General.
    Last Post: 11-10-2003, 02:22 AM
  5. Plymouth Clock
    Last Post: 11-08-2003, 01:47 PM
