Goal: $300, Received: $335.00 (112%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3201 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 9 of 9
    Default Medaille D' Bronze
    Got this out of an old antique store that close some years ago. Anyone tell me how old it is? It has a marble case and marked on the back of the movement, Medaille D' Bronze L Marti, 2002, 48.
    It needs some marble for the bottom. Anyone know were I could get some? Thanks, Mark
    More photos
    http://www.villagephotos.com/pubbrow...der_id=2000406
    Default Re: Medaille D' Bronze (By: swankyman)
    I did notice it has all three parts, movement, bezel and pendulum have matching numbers "2002"
    It is pin together and if you look inside it has JB in an oval mark.
    Looks to advance for me to fix.
    Mark, You might try a tombstone maker for the marble. Others have had limited luck with that source. Actually it is probably slate though. The T/S maker can tell for sure.
    Joe
    Registered user.
    Mar 2008
    New Zealand
    1,024
    I'm no expert on the subject but is it possible you've misread an S as an L? If it is S (for Samuel) then the Medaille de Bronze could refer to 1860 (meaning that the clock is post 1860 and pre 1889 when they won a Medaille de Argent (silver). Your L may also be an F. Fritz Marti won a bronze in the early 1900's.
    Thanks, Joe and Hayson, here are more photos of the name,
  6. #6
    Here's a good site for more info http://www.kerrysclocks.com/frenchdates.htm
    Mike C.
    aka
    clock whisperer
    Mike C.
    aka clock whisperer
  7. #7
    Registered user.
    Mar 2008
    New Zealand
    1,024
    ignore
    [edit=7386=1211680666][/edit]
  8. #8
    Yes Hayson hit a homerun!
    Now to get it fix up.
  9. #9
    Registered user. jmclaugh's Avatar
    Jun 2006
    Devon
    3,452
    Definitely S Marti. Most likely the JB in an oval is the clockmaker who finished a roulant supplied by Marti. The 4.8 is almost certainly the pendulum length in French inches. I have seen that Lourdelet patent mark before, I think it was to do with a pendulum locking device but can't remember for sure.
    Jonathan.
  1. Replies: 14
    Last Post: 04-16-2012, 10:52 AM
  2. S. Marti & Cie (Medaille de Bronze) clock identification
    By Cafeine in forum Clocks General.
    Last Post: 02-20-2006, 04:54 AM
  3. Cable Material: Bronze or Brass
    By Sid Daniels in forum Clock Repair
    Last Post: 09-25-2005, 11:56 PM
  4. Need help identifying bronze, garniture set.
    By mtdewhead in forum Clocks General.
    Last Post: 07-13-2005, 11:41 AM
  5. S Marti - Medaille de Bronze Movement/Parts
    By Grant Perry in forum Clocks General.
    Last Post: 04-10-2005, 09:32 AM
