Notice: This is an old thread. The last post was 1869 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 8 of 8
05-07-2008, 05:26 AM #1
Can you Lubricate a watch without taking it apart?
Hi, Being a relatively new collector to pocket watches and vintage wrist watches is it possible to lubricate a pocket or wrist watch without disassembly, Except for the removal of the movement from it's case. Thank You. RB. (VWC)
[edit=7441=1210158108][/edit]
05-07-2008, 06:15 AM #2Registered User
- Join Date
- Apr 2001
- Posts
- 5,739
Re: Can you Lubricate a watch without taking it apart?
Possible? yes...
Is it the CORRECT or BEST way... NO
others will elaborate... and this has been discussed before
also ask in the Watch Repair Forum.....
Chapter 17 North Carolina
http://www.nawcc-carolina17.org/default.htm
Chapter 149 Early American Watch Club .. Home of Russ Snyder Illinois CD database and Henry Burgell Serial number Look-up ... excellent research resources!
http://www.nawcc-ch149.com/ http://www.nawcc-ch149.com/pw_dbresearch.html
Chapter 149 Mentor List http://www.nawcc-ch149.com/mentor.html
05-07-2008, 06:52 AM #3
Best thing to remember in watch repairing.
There are no shortcuts!
Brian C.Brian C.
Chapter 149 Member
05-07-2008, 07:10 AM #4Registered User
- Join Date
- Dec 2001
- Posts
- 1,311
RB,
Shortcuts always seem like they work for awhile..Just remember that when you add oil to dirt it becomes a better Abrasive.. wearing down those really small pivots really Fast....Most people that oil without cleaning can get the movement apart alright, but cannot get it back together again..
Start with a proper cleaning and the watch will last another 200 years..
[edit=497=1210162381][/edit]
05-07-2008, 11:00 AM #5Registered User
- Join Date
- Aug 2000
- Posts
- 3,335
There are people who use a combination cleaner-oiler as you have suggested. We do not have nice words for such people. It is like dipping your car engine in a mixture of gasoline and oil and calling it an overhaul.
When we clean a watch we take apart all moving pieces, about 50 of the 150 parts. We clean it in a ultrasonic or mechanical bath with a cleaning solution followed by up to three rinses. Once the parts are dry we inspect them all to make sure they are clean, there are no broken jewel, warn or bent pivots and so on. We use a sharp piece of pegwood to clean the holes in the jewels, because agitating solution is not enough even with the watch in parts. Then we put it together and oil it using a micro-drop of oil in the pivots. If too much oil is used, then the oil will have a path to migrate away from the pivot. Image what it woud be like if the whole plate was oiled? Then we time the watch on a timing machine in several postions and see if it is keeping time appropriate to the grade. We make any necessary adjustments. Finally we run the watch several days in various positions to make sure it will keep running. A good watchmaker will then stand behind the overhaul for several months or even a year.
I just wrote an obituary for a friend who died recently. He worked at Hamilton Watch Company for many years. One of his former bosses said of him "He never took shortcuts, he never lied, he never stole and he was always there for you." In the watchmaking world, taking shortcuts is up there with lying and stealing.
Don
05-07-2008, 12:10 PM #6
As someone who hasn't been doing this for too long the challenge I always have is getting the right points on the pegwood for cleaning out holes - that and putting the correct amount of oil.
Luca
05-07-2008, 01:17 PM #7
Also after you peg the jewel holes and other holes, you need to make sure there is no peg wood left in.
My problem is to oil with just the right amount of oil.I do oiling under magnification as well.
Yes without taking the movement apart is like washing your feet with your socks on.Your feet are not really clean after.
05-07-2008, 01:39 PM #8Registered User
- Join Date
- Aug 2000
- Posts
- 3,335
To put in the right amount of oil, we have a set of Swiss flat tip oilers of different sizes. Touch the appropriate oiler to the oil in an oil cup and then touch the oiler to the well between the jewel and pivot. With pocket watches, most of this is done with the blue oiler (next to smallest). For very small pivots, the black (smallest) oiler is enough. The red and the green oilers are used for clock oil on the barrel arbor and such large pivots. When in doubt, use the smaller oiler and then look for a ring of oil around the pivot. You can always add more, but it is harder to remove an excess. Note, different companies use different colors for their small, medium and large oilers.
Yes, we all break the tip of peg wood off in the hole from time to time. I usually can remove it by putting a small piece of Rodico on the flat end of the the peg wood and pushing it into the jewel hole. When I remove the Rodico, the small piece of peg wood usually comes with the Rodico. I also have a very fine needle made from a black oiler that I once broke the tip off of. It is stoned to a very sharp point. If the Rodico trick does not work, I push the peg wood out with it.
Don
Another E. Ingraham Company watch - can you tell me abou it?
By Lucky12500 in forum American Pocket WatchesReplies: 1Last Post: 06-27-2012, 04:31 AM -
Can you ID this watch?
By keby724 in forum American Pocket WatchesReplies: 2Last Post: 05-13-2006, 08:16 AM -
Can you tell me about this watch?
By Meg in Carolina in forum American Pocket WatchesReplies: 12Last Post: 08-10-2005, 11:39 AM -
What can you tell me about my Pocket Watch?
By doug sinclair in forum American Pocket WatchesReplies: 5Last Post: 07-01-2004, 07:56 AM -
Can you identify the following 4 watch tools?
By WallHanger3 in forum Horological ToolsReplies: 7Last Post: 04-30-2003, 07:35 AM
About the Message Board
This will be an ongoing blog to chronicle the development and use of the NAWCC Message Board. Please reply with your thoughts as you feel appropriate. June 2013 marks the deployment of the last edition of vBulletin V4. We will continue using this version of the software until vBulletin V5 has been widely deployed and had a thorough shakedown. That may take as much as 3 years. In order to freshen the look of the message board, several changes have been made in this deployment. The most...
05-31-2013, 04:23 PM in Tom McIntyre
