Goal: $300, Received: $280.00 (94%) Contribute Now
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Default Clock Parts Terminology
    Registered User LaBounty's Avatar
    Aug 2002
    Mitchell, NE
    3,406
    Ref. "Practical Clock Repairing", Donald de Carle, FBHI, pgs. 9 - 12, 161.
    Default Clock Parts Terminology (By: bangster)
Name:	suspension parts.jpg
    Aug 2002
    Mitchell, NE
    3,406
    Default Re: Clock Parts Terminology (By: ogee_boy)
    American strike movement lever terminology...
    Ref. "The Levers of American Striking Movements", David J. LaBounty, CMC FBHI, pg. 3, fig. 1.
    Aug 2002
    Mitchell, NE
    3,406
    Default Deadbeat escapement parts terminology (By: LaBounty)
    Hey Joe-
    I'm sure Scottie can easily provide a drawing but I happen to have this one handy...
  6. #6
    Apr 2004
    Mesquite, TX
    938
    Default Deadbeat escapement description (By: LaBounty)
    THANKS LAB!
    JB, you can readily see the sequence here. Escape wheel is moving CW.
    1. A tooth lands on ENTrance LOCKing face and continues sliding across it.
    This sliding motion and distance is called OVERSWING. During this slide and overswing, wheel freezes - motionless - ergo - deadbeat.
    2. As pendulum returns, tooth meets IMPULSE or LIFT face and there, tooth pushes against face providing impulse to pendulum.
    3. After a brief moment or gap, called, "DROP", a tooth lands on LOCK face of EXIT pallet. Again it glides across the face during overswing. Pendulum returns again and another impulse provided to pendulum as tooth pushes against EXIT impulse (LIFT) face. Drop precedes next entrance lock.
    The terms used in this diagram are the same for a RECOIL escapement altho there are two differences in motion and design.
    1. After lock, pallet pushes wheel and entire train backwards - ergo recoil.
    It is the energy or potential stored in this recoil that provides impulse to the pendulum therefore;
    2. There are no impulse faces on the pallets and the pallet angles will differ from a deadbeat.
  7. #7
    Aug 2002
    Mitchell, NE
    3,406
    Default Re: Different Mainspring Arbors??? (By: LaBounty)
    Hey Scottie-
    Here's the platform escapement parts diagram you requested...
  8. #8
    Default Hairspring lever escapement (By: LaBounty)
Name:	hairspring lever escapement.jpg
  9. #9
    Aug 2002
    Mitchell, NE
    3,406
    Default Re: Clock Parts Terminology (By: LaBounty)
    Here are a few diagrams covering the Hermle balances...
  10. #10
    Default A generic count-wheel train, with warning (By: LaBounty)
Name:	count wheel mech w-warning.jpg
  11. #11
    Registered user. moe1942's Avatar
    Oct 2010
    Alexandria, La
    1,608
    Default Clock Parts Terminology (By: LaBounty)
    Ran across this and thought it might help clarify things when a problem is being sorted out.
    http://clock-dictionary.com/
    Pretty general in terms. Just a supplement to the thread we already have..
  12. #12
    Default Strip pallet -- recoil escapement (By: moe1942)
Name:	strip pallet copy.jpg
  13. #13
    Default Count Wheel Lever Assemblies (By: moe1942)
Name:	J-wire & warning lever copy.jpg
ID:	107615Click image for larger version.
Name:	J-wire & center cam.jpg
ID:	107616Click image for larger version.
Name:	both lever assemblies.jpg
  14. #14
    Default Grand Sonnerie Movement --Gustav Becker (By: bangster)
Name:	Grand Sonnerie mvt.jpg
ID:	107727Click image for larger version.
Name:	Qtr strike detail.jpg
ID:	107728Click image for larger version.
Name:	Hour Strike detail.jpg
Name:	Lower stuff detail.jpg
ID:	107730Click image for larger version.
Name:	HOW IT WORKS.jpg
  15. #15
    Default Elements of the Rack Strike (By: bangster)
Name:	Roulant r&s copy.jpg
ID:	107820Click image for larger version.
Name:	MC 1 r&s copy.jpg
ID:	107821Click image for larger version.
Name:	MC 2 r&s copy.jpg
ID:	107822Click image for larger version.
Name:	cuckoo r&s copy.jpg
ID:	107823Click image for larger version.
Name:	Snail Divisions copy.jpg
  1. Arbor Hook - Replacing a broken
    By bangster in forum Repair Hints, How-to's, Supplies and Services
    Last Post: 06-25-2012, 12:26 PM
  2. Hermle Chime-Strike Setup
    Last Post: 05-22-2012, 05:17 PM
  3. Clock Parts Terminology
    By TEACLOCKS in forum Clock Repair
    Last Post: 09-16-2010, 07:35 PM
  4. BOOKREVIEW: The British Museum Clocks by David Thompson (2004)
    By Fortunat Mueller-Maerki in forum Horological Books
    Last Post: 06-20-2005, 04:12 AM
