Goal: $300, Received: $260.00 (87%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2462 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 11 of 11
    Apr 2002
    19,594
    Blog Entries
    Default galleria grandfather clock
    This clock is for sale locally for under 150 dollars.I think it may be Korean made.Anyone else know of this name, Galeria?
    It winds with a key and i dont know much else about it.
    thanks.
    I was thinking about buying it and maybe change the movement.
    [edit=608=1209746001][/edit]
    Nov 2001
    South Easton, MA
    2,412
    Blog Entries
    Default Re: galleria grandfather clock (RE: Kevin W.)
    Doesn't ring a bell, but the case does not have a quality look to it. Plus, I bet the weights are decoration only; too far apart. Must be a spring-driven movement.
    Apr 2002
    19,594
    Blog Entries
    I have not seen it in person.Most likely a wood veneer case and weights are for decoration.if it were a solid wood case it would be worth the money to me.
    That's a 31 day Korean clock. Don't buy it.
    "Experience, Education, & Enjoyment." - Justin A. Olson
    Nov 2002
    38,594
    Kevin, they look much better from a distance than up close. Veneer over particle board. Likely freshly made Chinese.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  6. #6
    Apr 2002
    19,594
    Blog Entries
    Yes i cant stand particle board especially in a clock.
    Looks almost too good in the picture.
  7. #7
    I think that it would be vastly improved by the addition of coumns flanking the hood.
    It might not actually be particle board, but probably isn't the cherry it appears to be.
    It would make a very nice present for someone not too horologically minded, or not too sophiscated about antiques. Remember, things like this are sold brand new, in large numbers, every day, for 10X that price.
  8. #8
    Apr 2002
    19,594
    Blog Entries
    Maybe a good gift for my brother in law, the clock master.
  9. #9
    Nov 2002
    38,594
    Quote Originally Posted by Bill
    I suppose if you didn't know anything about clocks, you might pop $1,500 for a clock like that. I really hate telling them what they have when they call me to fix itThe columns are on the DELUX model:o
    [edit=795=1209764393][/edit]
  10. #10
    Hello
    Just a line to answer your question on the galleria clocks...The Galleria clocks were made in China ok I know this because i purchased them and all come with the words made in china on them.
    Have a Good Day
    cougar1
  11. #11
    Nov 2002
    38,594
    Default Re: galleria grandfather clock (RE: cougar1)
    Hi, Cougar 1, welcome to the message board.
    I hope some day the Chinese makers will put a bit of quality into these, so that I may be tempted to fix them. It's bad enough that you can't get any replacement parts.
  1. Previous Info on Grandfather Clock ID Request.
    By Paul Lopez in forum Clocks General.
    Last Post: 09-19-2006, 03:11 AM
  2. Grandfather clock stopping
    By Steve G in forum Clock Repair
    Last Post: 01-17-2006, 02:36 PM
  3. Colonial Zeeland grandfather clock Chimes
    By Scottie-TX in forum Clock Repair
    Last Post: 11-13-2005, 08:01 PM
  4. Identification of Grandfather Clock
    By mfolinger in forum Clocks General.
    Last Post: 02-12-2005, 02:20 PM
  5. Grandfather Clock
    By apjarvis in forum Clock Repair
    Last Post: 11-21-2004, 07:12 AM
