Goal: $300, Received: $80.00 (27%) Contribute Now
Page 14 of 16 FirstFirst ... 410111213141516 LastLast
Results 196 to 210 of 230
  1. #196
    Default Re: Some Jerome clocks for viewing (By: Jerome collector)
    Quote Originally Posted by Jerome collector View Post
    RM,
    Thanks for your thoughts. Jerome apprenticed as a house carpenter, and his earliest involvement in clock making was with dials and cases. By the 1840s, Jerome was owner of a large factory, and it's unclear how much direct involvement he would have had with construction techniques, even though he certainly had the background to contribute ideas. So, perhaps a bit of a stretch for me to refer to "Jerome's...experimentation." It might be more accurate to attribute that characteristic to his companies, which, to some degree, must have been a reflection of Jerome himself.
    One thing I should have mentioned is that the case is smaller than an ogee: 14" x 24 3/8", compared to 15 1/2" x 25 7/8" for an ogee from the same period.
    Mike
    A house carpenter...well, that's a bit different than a furniture maker though I will say that in smaller communities the house wright might do interior work as well making/repairing furniture when weather didn't permit them to pursue their primary trade or there was a lack of commissions to build homes.
    I also vaguely recall reading about some case furniture attributed to Jerome and possibly even signed by him?
    RM
  2. #197
    Registered User Jerome collector's Avatar
    Sep 2005
    Omaha, NE
    682
    Default Re: Some Jerome clocks for viewing (By: rmarkowitz1_cee4a1)
    Quote Originally Posted by rmarkowitz1_cee4a1 View Post
    RM
    RM,
    I don't remember ever hearing about furniture made by Jerome, but that doesn't mean much. However, in a curious, little, self-published (c. 1970) book by Joseph Reeves, there's a picture (see below) of the author sitting in a rocking chair in the "Old Fenn Home," which is apparently where Wm. B. Fenn, of stenciled glass fame, grew up. According to Reeves, the woodwork in the house, presumably including the fireplace mantle behind him, was finished by Chauncey Jerome.
    The theme and title of the book is "The Vanishing Footprints of the Old Plymouth Clockmakers." He devoted a paragraph to Jerome, quoted in part below:
    "He was a great promoter, but I doubt that he ever actually made a clock movement. He always had some good clockmakers with him. His downfall started when his brother Noble left him and the final blow was the leaving of Hiram Camp [mmb: Camp was Jerome's nephew and the founder of the New Haven Clock Co.]. He wound up broke and his dreams were over. He did a bit of writing about his life later on and sought to blame others for his downfall. But he himself, I believe, was responsible that very few of his footprints are showing on the sands of time."
    I particularly love his conclusion that few of Jerome's footprints remain on the sands of time. More recent authorities, such as Snowden Taylor and Chris Bailey, would likely take issue with that. Most would agree that Jerome ranks among the greatest of 19th century American clockmakers (despite never actually having made a clock movement!).
    Mike
  3. #198
    RM,
    Mike
    Wish I could remember where I saw it. Oh well.
    That guy is a old codger. Not quite on target in his sands of time comment.
    RM
  4. #199
    This recent acquisition is the Union by Chauncey Jerome. The case is darker than shown in the picture. I lightened the picture to show details better. The actual color is more like that of the example posted by Dave Coatsworth in this thread. The hands shown are new replacements. There is, unfortunately, no label. Chris Bailey's Bulletin Supplement # 15, Rags to Riches to Rags, shows examples of this clock in trade circulars from 1850 (p. 79, fig. 156), and 1853 (p. 92, fig 208).
    The numbers and chapter ring on the dial are somewhat faded but still quite legible. The dial is attached to its wooden mounts by two screws at the upper left and right, and by a pin at the lower left. The lower right shows no evidence of any attachment, either on the dial itself or the dial mount on the right. Note the similar mounting arrangement for the dial in this post of Dave Coatsworth’s thread. The dial mount on Dave’s clock, however, does have a mounting attachment (pin) on the lower right.
ID:	324891 Click image for larger version.
Name:	Union Left Dial Mount.JPG
ID:	324892 Click image for larger version.
Name:	Union Right Dial Mount.JPG
    The 30-hour movement is signed “Chauncey Jerome, New Haven, Conn, USA.” It is mounted by j-hooks on a wooden seat block shown in the pictures. There is also an upper small wood block securing the top of the movement. Part of it can be seen in the picture of the right dial mount above.
Name:	Union Movement Back.jpg
ID:	324894 Click image for larger version.
Name:	Union Movement Front.jpg
    The seat block itself is not attached directly to the backboard but to another “mounting block” that is attached to the backboard. At first, I thought this was a post-production addition to accommodate longer replacement screw for the seat block. However, I now think it original, because without it, the pendulum would likely run afoul of the alarm bell and possibly the alarm itself. There is a lot crammed into the limited space of that case (interior depth = 2 7/8 inches).
Name:	Union Movement Mount.jpg
    I think I’ve seen this style movement before, but I can’t place where. Perhaps someone can help me out of my befuddlement. Because of the shape of the escape wheel bridge, I suspect it is in the Jerome/New Haven family. In any event, the movement is similar to later New Haven 30-hour time and strike movements, such as the ones below. The one on the right is from Tran’s book on New Haven clocks (arlington books.com), page 305, fig. 1211. Note the escape wheel bridge.
Name:	O.B. Mvmt Back.jpg
ID:	324897 Click image for larger version.
Name:	O.B. Mvmt Front.jpg
ID:	324898 Click image for larger version.
Name:	Tran Column Movement.jpg
    A variety of 30-hour and 8-day movements seem to show up in the Union model, including fusee movements. Movements by A. S. Platt often show up in the Union, as well as in other Jerome clocks.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
  5. #200
    Moderator leeinv66's Avatar
    Mar 2005
    Launceston Tasmania
    7,785
    Blog Entries
    Several posts on Lithographs have been split into their own thread which can be found HERE
    Cheers
    Peter R Lee: AKA (Pee-Tah) from Australia
  6. #201
    Default Re: Some Jerome clocks for viewing (By: leeinv66)
    Here's a Jeromes, Gilbert, Grant & Co clock that was acquired recently. The dial, glasses, and doorknob are not original to the clock. The dial (not pictured) is a painted steel modern repro. But it runs okay.
ID:	343644   Click image for larger version.
ID:	343645   Click image for larger version.
ID:	343646   Click image for larger version.
ID:	343647   Click image for larger version.
ID:	343649   Click image for larger version.
  7. #202
    Nov 2002
    39,751
    Default Re: Some Jerome clocks for viewing (By: Pat L.)
    Nice clock, Pat. Looks like a prequel to the OG clock, perhaps just a bit earlier.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  8. #203
    Quote Originally Posted by Pat L. View Post
    This particular model of Jerome clock has been previously posted and discussed on this thread. See posting # 97. Find further information and recommendations for additional reading there.
    I've posted a teaser pic below.
    RM
  9. #204
    RM
    PS: note the religious imagery on the label in you clock. Mike (aka, Jerome Collector) has written about this interesting phenomenon on Jerome labels.
    RM
  10. #205
    Harold & RM,
    Thanks for your comments about the Jerome clock. I returned to the estate where the clock was purchased and found what may be the original dial. It seems to match up well with the original dial holes in the vertical supports. Thanks again.
ID:	344038   Click image for larger version.
  11. #206
    Default Re: Some Jerome clocks for viewing (By: Steven Thornberry)
    Quote Originally Posted by Steven Thornberry View Post
    Just for the record, this clock is shown on a Youtube video. It is a bit interesting, not only because it is a Jerome Empire style clock, but also because it was in Abraham Lincoln's law office. We have seen a few of these in this thread. The case served both for a 30-hour weight movement and an 8-day fusee movement.
    See this article in the current Bulletin by Mike Bailey (aka, Jerome Collector): http://docs.nawcc.org/Bulletins/2010...28_309_313.pdf
    A good read.
    RM
  12. #207
    Registered User George Nelson's Avatar
    Oct 2007
    Tennessee
    826
    Mike,
    Truly a superior and well-written article. I enjoyed reading it immensely, and it improved my appreciation of an identical clock (save for the tablet art) in my collection. Kudos, indeed!
    George Nelson
    Time is a great story teller... Irish Proverb
  13. #208
    Sep 2005
    Omaha, NE
    682
    Default Re: Some Jerome clocks for viewing (By: George Nelson)
    George,
    Thanks for the kind words. Although I followed your Sperry & Shaw thread, it was great to see it captured in the Bulletin. I always say that clocks have a story to tell; it's up to us to discover them. The story behind your clock is wonderful.
    When you get a chance, you should post pictures of your Jerome "Lincoln" clock.
    Mike
    - - - Updated - - -
    A good read.
    RM
    RM,
    Thanks for the pointer to the article. I wasn't aware it was out yet.
    Mike
  14. #209
    It was an excellent article, Mike. I even managed to stay awake past my 8 p.m. bedtime to finish it. It adds history to both Jerome and Lincoln. I am fortunate to own one of the 30-hour weight models, shown in post # 25 of this thread.
  15. #210
    Sep 2005
    Omaha, NE
    682
    Steven,
    Thanks, appreciate it. What I don't understand, though, is how you managed to go to sleep after reading the article. It's such a gripping story!
    Your clock has beautiful book-matched veneer. Certainly one of the nicest cases I've ever seen.
    Mike
  1. Some Help Needed for ID of very old clock
    By soaringjoy in forum Clocks General.
    Last Post: 10-01-2012, 02:20 AM
  2. Herschede #250 "The Clock" For Sale
    By Eric Estes in forum Clocks General.
    Last Post: 12-17-2006, 09:54 AM
  3. Replies: 4
    Last Post: 11-02-2006, 06:38 PM
  4. Info Needed on Mini Jerome Clock
    By Sooth in forum Clocks General.
    Last Post: 09-19-2006, 07:53 PM
  5. Tower clock for your home.
    By Albert in forum Clocks General.
    Last Post: 05-02-2005, 02:12 PM
