NOTICE Notice: This is an old thread. The last post was 3330 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Default K & D Staking Set
    What type of work is the K & D Staking Set with the JEWELLING TOOL ATTACHMENT for? Clock or Watch Repair?
    thanks
    tick
    Default Re: K & D Staking Set (By: ticktock)
    Watch repair... though you could also use it for some clock repair. The jewelling attachment is really just for watches.
    Quote Originally Posted by Timm
    Thanks Timm
    tick
    May 2005
    wisconsin
    1,727
    Tick
    Unfortunately There is little on the use of the watchmakers staking tool set other than some vague descripitions. I assume you are refering to the K&D "Inverto" set Fortunately it is a very handy tool for both watchmaking that it was desgned for and clock work especially a Micrometer jeweling attachment. You just have to be creative. One use of the micrometer handle would be to install pin wheel pins to a controlled uniform depth.
    Another would be to control the depth of a punch when straightening a difficult bent Arbor across two stumps that simply cannot be damaged. Even another is the controlled use of various punch shapes to form small metal parts/springs used in both clocks and watches. The list goes on and on and is limited only by your imagination.
    Jerry Kieffer
  1. Staking set cleanup
    By 107WestStreet in forum Horological Tools
    Last Post: 05-19-2016, 10:06 PM
  2. K&D vs Marshall staking sets
    By Jim D. in forum Horological Tools
    Last Post: 12-17-2006, 10:18 PM
  3. K&D Staking Set
    By tymekeypur in forum Horological Tools
    Last Post: 01-24-2003, 06:28 AM
  4. What is a staking set used for?
    By leehuff in forum American Pocket Watches
    Last Post: 01-09-2003, 11:56 PM
  5. Please advise me on purch of staking set
    By Cary in forum Horological Tools
    Last Post: 07-02-2002, 12:33 PM
