Lets eliminate the alarm from the equation. Take the connecting wire off the TOP connector or eliminate it completely. That will tell us whether the interference is coming from the disk itself or something else. If it still hangs up, it's either the disk or the lever that falls into the slot. If it doesn't, the problem is the wire or the alarm itself. You should be able to narrow it down and remedy it that way.![]()
