NOTICE Notice: This is an old thread. The last post was 3410 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    collector1
    Guest
    Default best way to clean & brighten brass--w/o ultrasonic
    Cleaning and removing all stains/tarnish, etc., from brass plates and parts on old movements drives me crazy---is there a simple (say liquid dip) that will do this AFTER the parts have been cleaned either manually or ultrasonically
    Actually, I prefer to clean parts the old fashioned way--by hand, not ultrasonically, using Chem Crest 270 and then 165. Maybe someone has a better method here as well. I disassemble everything first.
    PLEASE HELP!!!!!!!!!!
    Default Re: best way to clean & brighten brass--w/o ultrasonic (By: collector1)
    Yes, dip in household ammonia for about 3 minutes (full strength outside in fresh air). Brush the stubborn spots with a soft brass brush. Also check other threads here about issues with the use of ammonia. It's a controversial topic.
    BE SURE TO RINSE WELL AND DRY.
    Bob C
    [edit=4372=1200507861][/edit]
    Apr 2002
    20,011
    Blog Entries
    Collector.I dont fully understand.Movements that are not seen do not need to be shiney.They will tarnish, it is normal.If it is a anniversary clock for exaple the plates have a protective coating.
    I think this question was brought up before.
    Just my opinion, but i dont really want a shiney movement in a 130 year old clock, unless it is on display, eg, crystal regulators and anniversary clocks.
    Apr 2002
    20,011
    Blog Entries
    Should have re read your question.
    I use Deox 007 for cleaning. It is a biodegradable waterbased cleaner that also deoxidizes and brightens brass. If it still needs some work, a soft bristle brass brush works wonders. After cleanind rinse in Polytech 2CB. Both of these are products of US Polychemical and are available from Merrits. Nice thing is you can dump the stuff down the drain when done.
  6. #6
    Registered user. Mike Phelan's Avatar
    Dec 2003
    West Yorkshire, England
    9,823
    I am sure we have been here before!
    If it was polished when it was made, polish it, and vice-versa.
    Hiding tarnish if it cannot be seen is lazy. :o
    Here is what I do without any expensive chemicals:
    If clock is very dirty, an initial clean with your favourite brightener, maybe use an ultrasonic. Do any repairs at this point.
    Then you need three clock brushes, some Brasso or similar, IPA or petrol, a chalk block. A movement blower is useful.
    • Brush all parts, including wheel teeth, with Brasso, and wipe off the excess.
    • Wash all traces of Brasso off thoroughly and dry them.
    • Polish lightly with a soft chalked brush and blow any chalk dust off.
    The picture below is a clock I cleaned about 10 years age and it still shines.
    Mike - banned member of the throwaway society. :o
  7. #7
    Apr 2004
    Mesquite, TX
    938
    Ammonia does work or course. I prefer TARN-X. Costs a liddle more. Works a liddle bedder. Doesn't smell QUITE as bad but not a pleasant smell. It's a dip deal you like. I follow up with a light rub with 0000 steel wool for best results altho not necessary. Steel wool adds a gloss.
  8. #8
    Quote Originally Posted by Scottie-TX
    I didn’t know that TARN-X made a dip, where did you find it? All I’ve seen comes in a little bottle and seems to be similar to Brasso and similar polishes.
    I believe the main advantage of ammonia is that it’s very inexpensive and it has no abrasive component, so it simply washes away with water. If a polished (shinny bright) surface is the objective, then Tarn-X, Brasso, 0000 steel wool, or some other abrasive polishing compound is required.
    The choice to brighten and/or polish brass movements that are not normally seen has more to do with human expectations than horology. We expect apples in the store to be shinny, food to be a certain color, and brass to glisten. If someone brings me an old mantel clock from a yard sale and asks me to “clean” and service it, I usually brighten the brass plates because my customer expects to get back a clock that looks clean. Likewise, if I’m preparing a clock to sell, I’ll brighten the brass because many people judge the overall condition of the clock (correctly or incorrectly) by the way it looks. If the clock belongs to a serious collector, I usually advise against brightening brass parts that can’t be seen unless the customer desires this treatment. As for my own collection, sometimes I get a clock that’s just so grungy that there’s no choice but to brighten or polish the brass to make it even “decent looking”.
    Bob C.
  9. #9
    Registered Users
    Sep 2006
    metro NY area
    3,951
    Bob C.
    Bob,
    You said it very well; all I would add is that very often people "buy with their eyes". Thus there is much emphasis on making things look attractive, often to make a sale.
    It reminds me of cleaning engines on automobiles. It may make what is under the hood look more impressive, but it won't make it run any better.
  10. #10
    Apr 2004
    Mesquite, TX
    938
    "LOWES" hardware and "HOME DEPOT", for two.
  11. #11
    Dec 2003
    9,823
    Quote Originally Posted by R.
    My criterion is simply to make the movement as it looked when it was made - nothing more than that.
    On the rare occasions when I sell a clock, it's up to the prospective buyer whether they want it or not; the clock will look like it is at that time. If it dirty or clean, and they want the converse, someone else will buy it.
    Bob C.
    It is interesting, albeit a bit off-topic; we choose food by smell, taste and colour.
    If anyone has ever been to the Bradford (West Yorks) Colour Museum, they show a meal on a plate; green sausages, blue chips and purple peas! There is a caption saying something like "Would you eat that?"
    If I saw Russet apples that were "shinny" I would be very suspicious! Even the Discovery we pick off our apple tree are not shiny, but delicious.
    Back to clocks!
    [edit=1128=1200669474][/edit]
  12. #12
    we choose food by small, taste and colour.
    Mike - over here we choose by big, taste and color! Maybe that's why we have such a big obesity problem
  13. #13
    Dec 2003
    9,823
    Quote Originally Posted by shutterbug
    The UK seem to be second place in that one, SB; a lot of people are very concerned about kids having obesity problems here as well. I've fixed my typo but left it on here
  14. #14
    Registered User deena's Avatar
    Dec 2000
    Rural western New York
    442
    I also have the same question. I did a search on the subject but got hundreds of pages and could not narrow it down.
    I can't take the smell of the amoniated cleaner I now use in my ultrasonic. It smells up the whole shop.
    What works as well without the stink?
    clock_girl
    Wisdom doesn't always come with age. Sometimes age comes alone.
  15. #15
    Dec 2003
    9,823
    Deena
    I use ammoniated cleaner in a plastic box with a tight-fitting lid, and discard it outside, washing the parts there with boiling water.
    No smell at all.
  1. What's the best way to clean spring barrel's?
    By mr.jeepster in forum Clock Repair
    Last Post: 03-30-2009, 12:05 PM
  2. Best way to clean an Atmos?
    By fraggboy in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 02-19-2009, 01:13 AM
  3. Best Way To Clean & Shine "Marblized" Wood?
    By popeye in forum Clocks General.
    Last Post: 11-12-2007, 10:26 PM
  4. What is the best way to clean a painted base?
    By fille in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 10-16-2006, 06:44 AM
  5. Mechanical Wristwatch What is best way to clean a watch band?
    By PostalWatchGuy in forum Watch Repair
    Last Post: 04-04-2006, 09:47 AM
Members who have read this thread: 4
