Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Picture size question
    Default Picture size question
    What's the max size (in kb) for picture attachments?
    bangster
    1. Got a question about terminology & what clock parts are called? Click Here.
    Default Re: Picture size question
    not sure, but if you download to the thread, it automatically resizes...
    If you want the image to appear a larger size, you must host off-line and link to the URL...
    you can also upload to the user area under USER FILES download to it and link from there...these USER FILE can either be private or public.. the image will show full size...
    here is a 1079/1359 image downloaded to the thread
    Chapter 17 North Carolina
    http://www.nawcc-carolina17.org/default.htm
    Chapter 149 Early American Watch Club .. Home of Russ Snyder Illinois CD database and Henry Burgell Serial number Look-up ... excellent research resources!
    http://www.nawcc-ch149.com/ http://www.nawcc-ch149.com/pw_dbresearch.html
    Chapter 149 Mentor List http://www.nawcc-ch149.com/mentor.html
    here is an image stored in user files and linked
    Nov 2002
    28,764
    canada  ca ontario
    NAWCC
    I've noticed that I no longer need to resize my pictures to post, in fact I can no longer use the pic editor on the message board to do anything. Something has been recently changed. Not complaining, just pointing it out. Saves me lots of time not having to go though the pic editor to resize.
    But I do find oversized pictures to be a pain to look at, and it makes the whole thread too wide.
    [edit=795=1197519634][/edit]
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Dec 2002
    Dardanell, AR
    3,884
    usa  us arkansas
    There are a couple of things done to help speed up the Server Response time.
    Things that everyone can do is to:
    Post one picture perpost!
    Size all images to 450 px at 100 dpi MAXIMUM
    The speed of loading a page is determined by the Total Bandwidth being Used by that page.
  6. #6
    In a recent thread, a pic I was trying to post kept getting the message that it was too large. "Make it smaller and try again."
    How large is too large
  7. #7
    Dec 2002
    Dardanell, AR
    3,884
    usa  us arkansas
    Bangster: I do not know what you tried to do so I can not try to duplicate your problem.
  8. #8
    Feb 2003
    Southern California
    2,328
    Blog Entries
    usa  us california
    NAWCC
    Quote Originally Posted by kirxklox
    Kirxklox:
    Are you saying we should post only one photo per "Reply"? So if we have several pictures on the same theme, we should put each one in a seperate "Reply"?
    I am not sure what you mean by "per post".
    RobertG
  9. #9
    Aug 2000
    Boston. MA USA
    14,367
    Blog Entries
    usa  us massachusetts
    NAWCC
    Quote Originally Posted by bangster
    The attachment maximum size is currently set to 400 kb, I think. There are two setting for image attachments and images and the sizes are not the same. It may relate to what can be uploaded as opposed to attached.
    External references have no limits. It is pretty hard to impose those without code to edit the content of the image tags by acutally grabbing the target and putting it somewhere else. I don't think we will be doing that.
    Tom McIntyre
    If you don't learn to laugh at trouble,
    you won't have anything to laugh at when you're old.
    Will Rogers
    Please check out the new MB Software at this link
  10. #10
    Dec 2002
    Dardanell, AR
    3,884
    usa  us arkansas
    This should be a piece-of-cake:
    All tricked out. And then some.
    The difference is simple. bbBoard v2 is written in the most powerful scripting language on the Internet: Perl 5. You can change anything you want by hacking into the code -- add admin privileges, modify HTML, add database backends and create add-ons. But its flexibility is about more than hacking. You can also create templates for each page, change forum views, change colors and images and anything else. Want to integrate other software? Just use bbv2's programming APIs. When we say customizable, we mean it.
  11. #11
    Aug 2000
    Boston. MA USA
    14,367
    Blog Entries
    NAWCC
    Thank you Sam.
    Sometimes we should sit down and discuss the difference between marketing statements and specifications.
    Tom McIntyre
    Will Rogers
  12. #12
    Dec 2002
    Dardanell, AR
    3,884
    usa  us arkansas
    Quote Originally Posted by RobertG
    Kirxklox:
    RobertG
    RobertG: This MB allows 8 images per post and then some. That is over 800 KB per post if each image is 100 KB. This MB allow 20 posts per page and if each post had that many images it would take a LOOOOOONG time to open. Even at 1 image per post that is a fairly large bandwidth.
    I recommend each user only post 1 image per post.
    Each Reply is called a Post.
    [edit=876=1197605280][/edit]
  13. Default Re: Picture size question
    Quote Originally Posted by Tom
    Thank you Sam.
    Tom,
    Sam is right this board can be customized to do just about anything. The problem is we need to find someone that is willing to spent the time needed to make the changes that are being requested instead of just dodging the questions/request.
    Jeff Hamilton, FNAWCC, Certified Master Clockmaker www.clockmaker.com
  14. #14
    Dec 2002
    Dardanell, AR
    3,884
    usa  us arkansas
    Jeff: For the most part I am very happy with the Skinning that you did. The vibrant colors and the cool look background makes it interesting yet fairly easy to read and reduces eye-strain.
    If Tom wants to spend the Man Days to make more changes that is his perogative. I am positive it is easy as apple pie.
  15. #15
    Dec 2002
    Dardanell, AR
    3,884
    usa  us arkansas
    My last three posts about "a piece of cake" was suppose to be on this other forum.
    http://www.nawcc-mb.com/bbv2/bbBoard...=9;gtid=259641
  1. Same picture, different question
    By leeinv66 in forum Clock Repair
    Last Post: 07-12-2008, 11:07 PM
  2. Embarced bulb size question
    By 70chevelless in forum Electric Horology
    Last Post: 02-29-2008, 06:14 PM
  3. WALTHAM 12 SIZE QUESTION??
    By elginvanguard in forum American Pocket Watches
    Last Post: 02-24-2007, 07:55 AM
  4. Gustav Becker springs size question
    By Tunderer in forum Clock Repair
    Last Post: 11-01-2004, 03:03 AM
