NOTICE Notice: This is an old thread. The last post was 2189 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Default Gilbert Mantle - Speed Control
    Which way does one turn the speed adjustment ( S F) ?? If I want to speed up the clock do I turn the adjustment clockwise to the right (F) ?? Is this adjustment infinite or is it a cam that if over turned will result in slowing the clock instead of speeding up the movement??
    Nov 2002
    38,603
    Default Re: Gilbert Mantle - Speed Control (RE: newmarguy)
    Yes, turn it clockwise toward the "F" to speed up the clock. You are adjusting a screw, and once you run out of threads, you run out of adjustment. It won't start going the other way at the end of the adjustment
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    I am slow by about 5 min. over 24 hrs - would one turn the speed several rotations to adjust ?? Is this a coarse adjustment or would it be not unusual to have to turn the adjustment several complete rotations??
    Nov 2002
    38,603
    I would use about one turn, then note the difference 24 hours later. For fine tuning, let it run a week between adjustments. Is your pendulum bob adjustable at the bottom? If so, that is your coarse adjustment.
    Thanks for the info Harold, I will give that a try.
  6. #6
    Registered User John P's Avatar
    Sep 2010
    493
    A Gilbert mantle speeds up by turning the adjuster to the right. Make small adjustments like 1/4 turns and recheck in 24 hours. If you run out of adjutment , the adjustment assembly will stop . If you need more, shorten pendulum wire. Cut off the smallest amount you can, reform hook and retry.
    good luck
    john
  1. Lathe Speed Controller
    By bangster in forum Clock Repair
    Last Post: 01-21-2007, 07:48 PM
  2. Gilbert Mantle Clock "Acheron": need info
    By Birchwood in forum Clocks General.
    Last Post: 01-05-2007, 09:01 AM
  3. Dremel speed controller for lathe?
    By LloydB in forum Horological Tools
    Last Post: 08-16-2006, 12:52 AM
  4. Help Gilbert Mantle Horse Clock
    By Don DeMarcus in forum Clocks General.
    Last Post: 08-11-2004, 01:18 AM
  5. Variable speed control for lathe
    By GandalfPC in forum Horological Tools
    Last Post: 04-03-2003, 01:54 PM
