Goal amount for this month: 300 USD, Received: 210.00 USD (70%) Contribute Now
Donate whatever you can or Join the 16,000 other NAWCC members for only $72 (plus $10 for hard copy publications). Check it out here.
NOTICE Notice: This is an old thread. The last post was 2050 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    Default Gilbert Parlor Clock - runs how long?
    Hi All,
    I have a Gilber parlor clock, no model no on movement, but the remains of the label say Gilbert and the model is 'Thal...' the rest is missing.
    Anyway. it has small springs and the main spring is run out after @ 3 days. How long should this clock run? The spring is @ 3/8" wide. I don't know how long, but it's not the same size a smost American parlor clocks, obviously. Any help would be appreciated.
    Nov 2002
    28,980
    Default Re: Gilbert Parlor Clock - runs how long?
    Maus, sounds like you have a 30 hour clock. Running 3 days would not be unusual for these.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Quote Originally Posted by harold
    Thanks Howard, that is what I ws thinking, but I wanted to get confirmation.
    Feb 2007
    Avoca, Iowa-USA
    79
    Tran Duy Ly's Gilbert clocks shows a Thalba model with a one-day movement. It's 16 inches tall, 5 inch dial and the case has 7 "scallops" across the top in a staight row. Sort of a 1/2 roll below that.
    Registered user.
    Mar 2004
    Memphis Area, TN, USA
    491
    Hey Guys,
    I guess this would make a good "Cottage Clock". As I had read or heard they would run for 2-3 days so that if you wind and set it on Friday when you arrive it would run and strike until Sunday when most people headed back home. An interesting concept and believeable as well.
  1. How long has your mechanical clock been continuously running?
    By Douglas Ballard in forum Clocks General.
    Last Post: 07-23-2012, 09:39 AM
  2. Replies: 28
    Last Post: 01-08-2010, 04:43 PM
  3. Gilbert Banjo clock running problem
    By Weight Driven in forum Clock Repair
    Last Post: 12-09-2008, 07:33 AM
  4. How do I slow a Sessions kitchen/parlor clock?
    By Schmeltzer in forum Clock Repair
    Last Post: 01-20-2007, 07:21 AM
  5. Trying to find more info on Gilbert Parlor Clock/Joyce Model
    By wileecoyote in forum Clocks General.
    Last Post: 01-07-2007, 10:53 PM
