Rather than soldering you may want to try a dab of Loc-Tite #620 Paul.This product is made specifically for cylindrical slip type connections as opposed to the thread gripping Loc-Tite most of us are familiar with.I use it when I re-pivot an arbor and for wheels that tend to slip on their arbors.It only requires one little drop to do the job.The only thing I would tell you is that the mating area has to be absolutely clean and devoid of any grease or oil.The best thing about using this product is that if you want to break the connection down the road just heat the joint with a small butane torch and it'll break the bond.Originally Posted by Paul
I just thought I'd pass this process on to you as an alternative to soldering.
Bob Fullerton
