Goal: $300, Received: $115.00 (38%) Contribute Now
Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
  1. #31
    Nov 2002
    39,640
    Default Re: Changing Sehwa (Korean) 31 Day Mainsprings (By: sandcastcb750)
    I repaired one recently where the pinion on the second wheel had worn enough that it allowed the spring wheel to escape, a bit at a time. I noticed the problem before it became a UFO. Replaced both wheels.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  2. #32
    Registered user.
    Dec 2011
    sydney Australia
    1,824
    Quote Originally Posted by sandcastcb750 View Post
    Harold, you are correct about that winding those Liberty clocks. It has a real funky uneven feeling about it when winding. Maybe someday the key will become a spinning helicopter in the air.
    this one did
  3. #33
    Registered user.
    Oct 2010
    13,349
    Default Re: Changing Sehwa (Korean) 31 Day Mainsprings (By: dAz57)
    It is pictures like this that tell me to let down
    slowly on the keys. Every time one hammers them
    by dropping the key, on the click, is one time it is closer to fail
    and a black thumb.
  4. #34
    Default Re: Changing Sehwa (Korean) 31 Day Mainsprings (By: Tinker Dwight)
    Wow. I've never see a click break like that!
  5. #35
    Nov 2002
    39,640
    Default Re: Changing Sehwa (Korean) 31 Day Mainsprings (By: shutterbug)
    I've seen a few broken like that on Asian movements. Never had one break while I was winding one though.
  6. #36
    Default Re: Changing Sehwa (Korean) 31 Day Mainsprings (By: harold bain)
    Judging from the condition of the teeth, I wonder if it blew by a few teeth and anchored itself solidly into a 'good' one after it picked up considerable speed?
  7. #37
    Nov 2002
    39,640
    I suppose it could have been caused by having the key slip while winding, allowing a quick release of teeth, then have the click catch one, fracturing the click with the force of the runaway click wheel.
  8. #38
    Default Re: Changing Sehwa (Korean) 31 Day Mainsprings (By: lirenrui)
    A friend of mine spent a year in Korea while stationed there in the Army. He came back with the saying "almost good".
    That click could have been bad metallurgy and was destined to fail.
  9. #39
    Apr 2002
    20,082
    Blog Entries
    Just glad my thumb and fingers was not on the key when that happened, it hurts just thinking about it.
  10. #40
    Registered user.
    Dec 2011
    sydney Australia
    1,824
    Quote Originally Posted by harold bain View Post
    don't know, the ratchet teeth were pretty good, the click was thin, only half the thickness of the ratchet wheel teeth, I replaced it with a click twice as thick.
    here is another shot of the click off the wheel, it looks it was torn, it is still hanging together by a thread
  11. #41
    They don't just break. It's usually a mishap as mentioned by Bugs and Harold. Or, just bad winding habits.
    When a ratchet hangs, tip to tip, there are at least 5 things that can happen. The click can snap directly into the present gullet of the click wheel, the click can snap out of the wheel and into the next gullet, or the click can snap out for a short length of time and catch soundly two or three gullets down, it can snap out for a longer length of time and skate over several click wheel teeth before landing solidly somewhere, or the outward snap can bend or break the click spring and allow a full let down.
    Each of these 5 steps spells the dissipation of more and more energy. The first one would probably go unnoticed. The second probably would not do much damage. Three and four will cause damage but the damage might be overlooked until further damage is caused by continued use. The fifth one can wreck your clock movement and your poor fingers.
    My 2, Willie X
  12. #42
    does anyone have a internal type picture of above clock--found extra piece on bottom?? Do not know if it is a replaced item or goes somewhere else. looks like possible flat spring
  13. #43
    Dec 2011
    Brockville, On Canada
    5,552
    Default Re: Changing Sehwa (Korean) 31 Day Mainsprings (By: capone47)
    I think it would be most helpful if you can post a picture of what you found, then we could be more helpful.
    David
    David S
  14. #44
    Nov 2002
    39,640
    If you show us a picture of what you have, good chance we can tell you if it could be from your clock movement.
  1. Korean 31 day mainspring removal?
    By Frank Manning in forum Clock Repair
    Last Post: 08-26-2011, 09:11 PM
  2. Korean 31 day
    By joe4227 in forum Clocks General.
    Last Post: 12-28-2009, 01:47 PM
  3. beacon korean 31 day
    By clayton cooper in forum Clock Repair
    Last Post: 11-01-2008, 10:08 AM
  4. My first clock caper- Starring my OTRON Korean 31-day clock .
    By plantluvver in forum Clocks General.
    Last Post: 09-19-2006, 07:30 AM
  5. korean 31 day movement regulator clock
    By 107WestStreet in forum Clock Repair
    Last Post: 02-25-2006, 08:22 AM
