Results 1 to 12 of 12
Thread: 1869 ELGIN KEYWIND
    Default 1869 ELGIN KEYWIND
    This old elgin came across my desk today. It has a gold filled case with the recessed anchor mark. Isn't that a dueber mark? Is the case original to the watch? The case screws line up with the marks...
    These old keywinds are getting scarce in this kind of condition-still running strong at 137+ years!!
    Default Re: 1869 ELGIN KEYWIND
    HERE'S SOME PICTURES
    Attached Thumbnails Attached Thumbnails DSC01803.JPG   DSC01800.JPG   DSC01797.JPG
    Brian,
    The case may be made by Ladd.. check where the hinged bezel seats by the front cover hinge.. If there is a patend date on the rim it is most likly made by Ladd.. As far as original to the movment, it appears there is another case screw mark just above the current one..
    Yes, now that I take a second look, There is another screw mark there-rats.
    No patent mark on the rim for Ladd...
    Still a nice watch tho...
    Just noticed that the movement is turned slightly and the 3o'clock postion isn't lined up exactly with the stem. I think the other case mark is where it is supposed to be...
  6. #6
    Thanks,I found the Ladds mark june 11 '67 Original after all-SWEET@!!
  7. #7
    HERE'S A PIC
  8. #8
    Hi Brian -
    Nice watch and I like those Ladd cases!
    There was a discussion on Ladd cases on this board a few years ago and I posted some images from a Ladd case catalog to the thread, you might find this interesting and here is a link to that thread ...
    http://www.nawcc-mb.com/bbv2/bbBoard...619#gpid204619
    ... and if you click any of the listed page numbers in my post it will take you to an image of that page of the catalog.
    Fred
    Fred Hansen
    NAWCC #109682
  9. #9
    Sep 2006
    North Andover, MA USA
    640
    usa  us massachusetts
    Brian,
    I have an OF Am Waltham Watch Co. (R. E. Robbins) keywind. It is in a nice 3 oz Am Watch Co. coin silver case. Since there is no stem, it appears that you can orient the watch any way you want in the case. So, like yours, there are multiple screw marks around the area of the correct orientation.
    Cheers,
    Stan
  10. #10
    I believe that the 18s keywind movements have a small peg or pin on side of the pillar plate at about the 11 o'clock position that corresponds to the small hole on the dial side of the case that receives this peg. That way the watch is correctly orientated in the case, be it a hunter or open.
    Am I mistaken?
  11. #11
    Vic,
    You are correct.. If the pin is missing it is possible to misalign the movement and "create" another case screw mark close to the original.. it then becomes a question of what happened to the original pin.. they usually do not fall out, with out some serious mistreatment....If you view Brains last photo, there is something misshaped on the rim by the patend date, which I believe is where the pin hole is located..
    [edit=497=1184540213][/edit]
  12. #12
    John,
    I am thinking that since the movement and case were sold seperately at this time period, when it was cased up the person tightened it up without realizing it would only line up with the winding hole in the dust cover in one position??
  1. 1873 PL Elgin Keywinds
    By dweiss17 in forum American Pocket Watches
    Last Post: 06-02-2010, 04:40 PM
  2. Hampden Keywind Pocket Watch
    By Wes in forum American Pocket Watches
    Last Post: 01-31-2007, 12:01 PM
  3. Elgin 7-Jewel Keywind
    By Joe Pentecost in forum American Pocket Watches
    Last Post: 05-28-2006, 07:33 AM
  4. Anyone Remember This Lord Elgin Diamond Bezel Watch?
    By Andy in Boca in forum Wrist Watches
    Last Post: 01-05-2006, 04:50 AM
  5. Elgin G.M. Wheeler Question
    By java1214 in forum American Pocket Watches
    Last Post: 05-25-2005, 09:44 AM
