NOTICE Notice: This is an old thread. The last post was 910 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Moderator leeinv66's Avatar
    Mar 2005
    Launceston Tasmania
    7,338
    Blog Entries
    Default Gilbert Blackbird Date??
    Hi all, this is the latest addition to my collection. It was in pretty bad shape, but has come up OK with many hours of coaxing. Can anyone let me know the year Gilbert made this Blackbird model was make?
    The only before photo I have (thanks Scottie)
    The case after restoration
    The clock now
    Cheers
    Peter
    Cheers
    Peter R Lee: AKA (Pee-Tah) from Australia
    Default Re: Gilbert Blackbird Date?? (RE: leeinv66)
    Tran shows a marbelized Gilbert Blackbird for 1904. It came with white, cream, or perforated dial. Marbelized in Italian, Scotch granite, or red. Tran's catalogue picture has Arabic numerals rather than Roman (for what that's worth). You did an excellent job of restoration!
    [edit=1153=1181653910][/edit]
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
    Mar 2005
    Launceston Tasmania
    7,338
    Blog Entries
    Thanks Steven, the info and the kind words are much apprecitated.
    Cheers
    Peter
    Cheers
    This is a very handsome job, indeed.
    I have a Blackbird of the same era -- unrestored despite having once served as a home for a mouse in an out house -- and the movement on mine bears the date 1908. Face is arabic. Replaced mainsprings in early 1980s.
    Over the years I've had problems with accuracy. Patience is required with the pendullum. The case is not very tight; lubricants thus collect dust and are probably to be avoided.
    Mar 2005
    Launceston Tasmania
    7,338
    Blog Entries
    Default Re: Gilbert Blackbird Date?? (RE: sowder)
    Quote Originally Posted by sowder View Post
    Hi Sowder and welcome to the board! Yes, these are great looking clocks and I treasure mine. I find that Gilbert regulating assemblies in general are quite touchy. So I fit mine with an adjustable bob for fine tuning. This one never varies more than two minutes over a seven day period.
    Cheers
  6. #6
    You did an awesome job!!! I just finished one myself.
  1. Gilbert steel plates, Guide to date?
    By Dave D in forum Clock Repair
    Last Post: 02-14-2009, 07:22 AM
  2. Did Gilbert date movements?
    By Steven Thornberry in forum Clocks General.
    Last Post: 01-16-2008, 05:04 PM
  3. Wm. L. Gilbert - Date? Model Name?
    By Joseph Bautsch in forum Clocks General.
    Last Post: 02-21-2007, 08:06 AM
  4. Gilbert-Blackbird.....FROZEN!
    By J.S.H. in forum Clock Repair
    Last Post: 01-15-2007, 05:08 PM
  5. Gilbert Mirror Side Date Manufacture?
    By ClocksCollector in forum Clocks General.
    Last Post: 01-06-2006, 10:58 AM
