Goal: $300, Received: $275.00 (92%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3728 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    Registered User Jeff C's Avatar
    May 2005
    Seven Fields, Pennsylvania
    2,119
    Default 8mm Lathe collet sizes.
    Hi,
    I am wondering is there a chart or something that shows the ID's in inches for collets that are numbered such as 1-50. For example a collet that is 13/64" etched on the head would be what number 1-50?
    The few I have are all numbered and some of the ones I see for sale are stated in inches such as 13/64",1/64" etc. I just don't want to buy what I do already have.
    Many thanks for your help.
    Registered user.
    Sep 2000
    York, Pa.
    247
    Default Re: 8mm Lathe collet sizes. (By: Jeff C)
    The sizes are .1MM increments. If you go to www.StarrrettCollets.com they have a chart if you scroll to the bottom of the 1st page.
    Malkin Shaw
    May 2005
    2,119
    Thanks for the info Malkin. I wasn't aware the relation between the size# and actual ID measurements was that easy to know ie. #50=5mm.
    Quote Originally Posted by Jeff
    Isn't it odd that we in the U.S. measure the thickness(strength) and width of mainsprings metrically but the length in inches? I'm sure they don't file springs that way in Switzerland but I've never seen any msg. length marked metrically here..
    -Cort
    Quote Originally Posted by 4thdimension
    -Cort
    It has been my experience that most suppliers' catalogs list mainspring specs in both English and metric measurements.
    -------Tony-------
    Arizona Clock Repair
  1. 6mm Lorch Schmidt Lathe Collet thread size?
    By walthambarmy in forum Horological Tools
    Last Post: 05-23-2012, 05:41 PM
  2. Help re collets for 8mm lathe
    By gingi310 in forum Horological Tools
    Last Post: 03-28-2011, 03:11 PM
  3. Jewelers lathe collet question?
    By Jeff C in forum Clock Repair
    Last Post: 06-07-2006, 10:57 AM
  4. Lathe Collets
    By Wayne C. Anderson in forum Horological Tools
    Last Post: 03-25-2006, 04:21 AM
  5. Lathe Collets
    Last Post: 08-04-2002, 02:08 PM
