NOTICE Notice: This is an old thread. The last post was 3909 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Default Emil Schmeckenbecher Mantle Clock - Dunhaven
    I just purchased a mantle clock marked Dunhaven on the front - Made in Germany. The movement is Emil Schmeckenbecher - Made in Germany 2 jewel - 340-020. Can anyone give me any information as to the age or ?.....It is in perfect condition and has never been wound until I did so when I got hom. Wood case - silver face. Thank you in advance for the help. Dan - tietzedet@aol.com
    Nov 2002
    39,743
    Default Emil Schmeckenbecher Mantle Clock - Dunhaven (By: tietzedet)
    Hi, Dan. The movement in your clock is a Hermle, and may have a date code on it. I would guess 1970's or newer.
    Schmeckenbecher is a case builder/assembler, who made a lot of cuckoo clocks over the years, but never made movements. HTH
    Harold
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Thanks for the help - so are you saying that Emil S. put the clock together. Is it a quality movement Hemle? Thank you.
  1. Emil schmeckenbecher cuckoo clock
    By BOBJAYR in forum Clock Repair
    Last Post: 07-06-2011, 12:07 AM
  2. Enfield Mantle Clock problem
    By Kate in forum Clocks General.
    Last Post: 11-10-2006, 06:27 AM
  3. Schmeckenbecher mantle cuckoo clock
    By Michael Vala in forum Clocks General.
    Last Post: 03-01-2005, 05:31 AM
  4. old sessions black mantle clock
    By LaBounty in forum Clocks General.
    Last Post: 03-28-2004, 03:40 PM
  5. mantle clock
    By eskmill in forum Clocks General.
    Last Post: 11-04-2003, 01:55 AM
