Goal: $300, Received: $20.00 (7%) Contribute Now
Page 67 of 67 FirstFirst ... 17576364656667
Results 991 to 1,002 of 1002
  1. #991
    Default Re: Illinois private-labels (By: Dave Coatsworth)
    260480 - 'Iowa Watch Co., Star of the West', model 2, grade 101, 11J, SS dial
ID:	354833   Click image for larger version.
  2. #992
    Registered user. pmwas's Avatar
    Dec 2010
    Sosnowiec, Poland
    1,208
    Blog Entries
    136
    Here's a beauty - Charles Sumner, Boston No 210583.
    That's why I needed the morning glory hands and a case, Dave
    This project is bound to be a success, as this movement is just fine, nothing wrong with it at all.
    It has the original (pin-foot, BTW) dial as well.
ID:	355268   Click image for larger version.
ID:	355269   Click image for larger version.
  3. #993
    Dec 2010
    Sosnowiec, Poland
    1,208
    Blog Entries
    136
    Default Re: Illinois private-labels (By: pmwas)
    It is listed as model 1 on pocketwatchdatabase, but it's clearly a model 2. I admit I did not pull the dial of yet, but since there are no dial screws on the side of the pilar plate, I'm pretty sure it's fine.
  4. #994
    Nice one, Paul! I just picked up a model 3 Charles Sumner, which I should have to show in a few days.
    Meggers and Ehrhardt list the entire run from 210,001 to 211,000 as model 1. But, I also have a model 2 out of this range (210,044). Clearly it was a mixed range or there were sub-runs that have not been identified.
  5. #995
    Here's my 17J LS model 3 "Governor" with sn 210,432 ... ... with a couple mixed screws ...
Name:	Illinois 18s 16-17J gr 103 5th pinion sn 210432.jpg
    Last edited by Dave Coatsworth; 09-01-2017 at 12:12 PM. Reason: Remove oversized photo
    Member Chapter 149
  6. #996
    Default Re: Illinois private-labels (By: Dave Chaplain)
    Seems the only thing consistent about this range is that it is all grade 103. But a mix of models 1, 2, and 3.
  7. #997
    5101 - 'S. T. Little, Cumberland, Md.', model 1, Currier grade, 11J, SS dial. (If you think you're seeing double around the top of the seconds bit, it's because of the bullseye crystal installed on this one.)
ID:	355884   Click image for larger version.
  8. #998
    39057 - 'Frank M. Jackson, Chico, Cal.', model 1, Hoyt grade, 9J, SS dial.
ID:	355893   Click image for larger version.
  9. #999
    211109 - 'Charles Sumner', model 3, grade 103, 17J (verified by pulling dial and despite report that this is a 16J run), DS dial.
ID:	355895   Click image for larger version.
  10. #1000
    1000 Posts!
    324551 - 'Standard Watch Co., Pittsburgh, Pa.', model 3, Grade 65, 17J (verified)
ID:	355897   Click image for larger version.
  11. #1001
    Fred,
    I have just purchased this and it's on it's way -
    Illinois
    17 Jewel
    Grade 69
    Model 6
    Serial no. 2939716
    Dial and movement marked 'John P. Hess Co. Fond Du Lac, Wis.'
ID:	355910Click image for larger version.
  12. #1002
    Default Re: Illinois private-labels (By: newrailway)
    1165407 - 'I. Brilleman, Albany, NY', model 4, IWC grade, 7J, SS dial
ID:	356524   Click image for larger version.
  1. Illinois private label watches
    By bernie levine in forum American Pocket Watches
    Last Post: 04-08-2012, 07:10 AM
  2. Illinois Private Label
    By John Cote in forum American Pocket Watches
    Last Post: 10-16-2008, 05:09 PM
  3. I need help on illinois private label watch.
    Last Post: 10-03-2004, 10:31 AM
  4. John Miller Cairo Illinois Private Label
    By Kent in forum American Pocket Watches
    Last Post: 09-22-2003, 06:32 AM
  5. Illinois Private Label? Help Identify.
    Last Post: 04-12-2001, 05:07 PM
