Goal: $300, Received: $275.00 (92%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3845 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 10 of 10
    Default Sessions movement - assembly and parts info help
    Need information to orientate strike train gears and levers as well as identify and purchase a verge, suspension spring, pendulum leader and bob.
    The clock movement is a old Sessions Time and Strike, open frame with two hammers. No model number on the movement. Frame is 3.5" wide, 5.125" high, verge will be with a long leader bent over the top of the movement.
    Is there a diagram showing the orientation of parts in the strike side for aligning gears, interposers etc. ?
    I am a customer with and have a catalog from Time Savers.
    I bought this movement to gain experience with this type of movement. Have it disassembled, cleaned, polished and ready for assembly.
    Thanks, Doug
    Default Re: Sessions movement - assembly and parts info help (By: Doug Henry)
    hi doug,send me an e mail pocketwatch@hot.rr.com and i will send you some close up pictures, maybe they will help.
    cpatrick
    Sounds like a "bim-bam" movement. Post some pictures and we can help you set it up.
    Registered User timewaster's Avatar
    Sep 2004
    Fredericksburg, Texas
    265
    Here is a site that will help you. http://www.abouttime-clockmaking.com...s/Levers-2.pdf
    Yes, Bim Bam
    Patrick has send several pictures that will help. It will take some time to study them.
    Attempting to upload my pictures.
ID:	363   Click image for larger version.
ID:	364   Click image for larger version.
  6. #6
    Very nice article, thank Bob.
  7. #7
    If you study David LaBounty's diagrams, you'll be able to set it up. You need everything set up right when you reassemble, but if you get it together and it does not behave right, most adjustments can be made without taking it apart again. Just give us a shout
  8. #8
    So, the maintenance cam will turn on the shaft. But I think the other gears must be lined up. It is the stop/warning wheel that has a pin in it that catches on the stop lever?
    I will tinker with it. More levers etc. than what I am accustom to with Hermel movements.
    Other questions: Can someone help identify a verge, suspension spring and dimentions of pendilum leader? These are missing from this unit.
    Doug
  9. #9
    Member
    Guest
    Default .. (By: Doug Henry)
    [edit=5920=1171299769][/edit]
    [edit=5920=1172266428][/edit]
  10. #10
    About your verge - do you know if this is a half deadbeat? If the motion of the escapement turns with the teeth pointing forward, it is. If the motion is with the teeth pointing backward, it isn't. We need to know that before offering advice on a verge.
  1. French Movement HELP and PARTS needed
    By Scott Andersen in forum Clock Repair
    Last Post: 10-17-2011, 10:40 AM
  2. Engraving movement parts to help re-assembly
    By peterzay in forum Watch Repair
    Last Post: 05-01-2011, 02:40 AM
  3. ID and info help on this Reymond Locle
    By LJballer in forum European & Other Pocket Watches
    Last Post: 06-19-2007, 05:12 AM
  4. Sydney Advertising Clock Info and Parts Needed
    By mlschlot in forum Clock Repair
    Last Post: 04-20-2005, 09:50 AM
  5. Ingraham case and Sessions movement?
    By lpbp in forum Clocks General.
    Last Post: 04-05-2004, 05:45 AM
