NOTICE Notice: This is an old thread. The last post was 5069 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Default Clean, oil, and adjust 400 day clock.
    The following is a list of what I do to a 400 day clock to COA.
    1) Completely tear down the mvmt and clean.
    2) Completely dissassymble the spring barrel and clean thouroughly. I use Slick 50 to oil the main spring and let set for a while to not have any excess left on the spring.
    3) Peg out all pivot holes and use Pith wood to ensure clean.
    4) Check all pivots to ensure polished or polish same.
    5) Reassymble carefully to prevent bending PIVOTS. These pivots are not hardened and bend easily.
    6) Take care in putting the hour pipe, minute pipe and minute hour wheel back with the preasure washer.
    7) These clocks are only difficult because of the loss of power up the gear train when they are under powered in the first place.
    Any one desiring a picture of parts or how their mvmt should look, I can provide here by request. If I have missed anything or am unclear on anything please ask.
    kirxklox (Sam Kirk)
    Chapter 149 Member #100
    Web Horology MB
    Edited to combine two posts by kirxklox
    [This message was edited by Phil Schilke on May 12, 2003 at 18:14.]
    Default Clean, oil, and adjust 400 day clock. (By: kirklox)
    kirxklox (Sam Kirk)
    Web Horology MB
    Instructions on setting Beat and rotation. By permission Bill Ellison, The Horolovar Co.
    kirxklox (Sam Kirk)
    Web Horology MB
  1. Schatz and Kundo 400 day clocks
    By swankyman in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 12-26-2009, 11:31 AM
  2. Difference between standard, junior, miniature and midget 400-day clocks?
    By Spaceman Spiff in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 10-25-2009, 08:10 PM
  3. Schatz and Kundo 400 day clocks
    By swankyman in forum Your Newest Clock Acquisition
    Last Post: 10-04-2009, 10:58 PM
  4. Seeking 400 day Clock information and Model
    By Andy Krietzer in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 08-09-2004, 06:03 PM
  5. Cleaning of tarnished 400 day clock case.
    By Original Dial in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 05-01-2002, 02:00 PM
