Goal: $300, Received: $165.00 (55%) Contribute Now
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
  1. #31
    Registered User Jim Haney's Avatar
    Sep 2002
    Decatur, TN.
    4,990
    Default Re: New Hamilton 16s RR Case Discovered ! (By: l3up)
    804627 2575220- 992 YGF Jim Haney
    804707 empty YGF Jim Haney
    804959 1733183-992 YGF Fred's Sighting
    805147 2574067-992 YGF Fred's Sighting
    805541 2576525-992 YGF Fred's Sighting
    805779 2574161-992 YGF R. Romero
    805885 empty YGF Jim Haney
    805909 empty YGF Jim Haney
    806136 2530148-992 YGF Charlie Sides
    806183 2574510-992 YGF Weldon Hopkins
    806324 2538387-974 YGF Charlie Sides
    806328 2575823-992 YGF Weldon Hopkins
    806619 2538745-974A WGF Charlie Sides *
    806704 2536535-974S WGF Weldon Hopkins
    806779 990 move't WGF David
    806779 2421761-992 WGF luvsthetick
    806845 1115278-992 WGF Jim Haney
    807318 1615814-992 WGF Jim Haney
    * Factory Boxed Set
    Jim Haney
  2. #32
    Mar 2002
    SC
    899
    Default Re: New Hamilton 16s RR Case Discovered ! (By: Jim Haney)
    Jim
    Here's link to the boxed #9 set with 974 spl. That thread also shows another 974 spl in #9 case that I sold.
    http://mb.nawcc.org/showthread.php?6...-of-the-puzzle
    Boxed set 806619 974spl 2538745
    sold watch 806324 974spl 2538387
    Charlie
  3. #33
    Sep 2002
    Decatur, TN.
    4,990
    Default Re: New Hamilton 16s RR Case Discovered ! (By: crsides)
    Charie, Thanks, I added them
    806357 2576377-992 YGF Fred's Sighting
    807098 1619769-992 WGF Weldon Hopkins 8-1-12
    * Factory Boxed Set
    Jim Haney
  4. #34
    Sep 2002
    Decatur, TN.
    4,990
    Default Re: New Hamilton 16s RR Case Discovered ! (By: Fred Hansen)
    bumped, new data added
    Jim Haney
  5. #35
    Jim, I have one of those, with a 992E. Movement S/N is 2607527 I'll post the case S/N when I get home.
  6. #36
    Default Re: New Hamilton 16s RR Case Discovered ! (By: Kent)
    I , too might have walked by this. In fact, maybe I did. Congrats and thanks for sharing. I was curious to see pics of the inside of the case back. Jim, you must have read my mind. Thanks for sharing. Don, you are an amazing researcher. Darn!!!! One more rare acorn to try to add to my squirrel's nest.
    Skip, that Hamilton Nut
  7. #37
    Default Re: New Hamilton 16s RR Case Discovered ! (By: skippp66)
    Case Serial Number is 804888
  8. #38
    Default Re: New Hamilton 16s RR Case Discovered ! (By: GeneJockey)
    Hey, should this case have a sleeve? I had this watch serviced some years back by a watchmaker I don't think was very good. When it came back, the winding is incredibly stiff and the stem is loose, i.e. the whole stem and crown slide up in the case by a couple mm.
    If so, anyone know where I can get the proper sleeve?
    THANKS!
  9. #39
    Registered user.
    Apr 2012
    Cypress, Texas
    261
    Quote Originally Posted by GeneJockey View Post
    THANKS!
    Its a lever set watch, so I would think there would be no need for a sleeve.
  10. #40
    Default Re: New Hamilton 16s RR Case Discovered ! (By: Phil7153)
    can't remember on these, been a while since i held one
    it may not have a sleeve, but a shouldered stem ... the case should have some dustproofing features, like the crown fitting down over the tube with a close fit.
    sometimes stiff winding can be a misalignment of the movement in the case, tilting the stem. do you know if he replaced the stem? could be wrong one.
  11. #41
    Sep 2002
    Decatur, TN.
    4,990
    Default Re: New Hamilton 16s RR Case Discovered ! (By: terry hall)
    Gene,
    Terry is correct on the stem, it does have a large shoulder that acts as a dust proof barrier. There is no sleeve for these case, as is the normal for most of the short pendant Hamilton RR cases.
    The correct crown with this stem make it a straight stable winding tool for the movement.It will not have any slop or play sideways.
    Show a picture of your crown and bow area and I can tell you if everything looks correct.
    Jim Haney
  12. #42
    Here are two views of the crown, showing how loose it is. It is tightened all the way down on the stem, but still has a couple mm of slop.
    Here's the crown, stem, and the bow area of the case.
    The shoulder has been hand-filed at the top - not sure why. And if you look at the square portion of the stem you can see it's starting to round at the corners. If this ever was the correct stem, it's been so butchered that it no longer fits.
  13. #43
    Sep 2002
    Decatur, TN.
    4,990
    Gene,
    The stem looks bad on the winding end but I don't how bad. The notch in the bow supports looks normal , they are made that way. The base that the crown sits on looks like it was filed down and that could be the problem.
    Send me a PM about it, I have those stems.
    Jim Haney
  14. #44
    It's REAL bad, Jim. The corners are increasingly rounded off. I believe the winding issues are both the case problem we're discussing and perhaps a mainspring issue.
  15. #45
    Sep 2002
    Decatur, TN.
    4,990
    I am adding to this 12 year old thread.
    I bought a Model 9 Boxed set from my friend Charlie Sides.
    It is the only known example of a Factory Boxed set with a (Early) Model 9 case from Fahy's.
    Jim Haney
  1. Elgin RR case model number
    By Jack Williams in forum American Pocket Watches
    Last Post: 04-15-2011, 03:56 PM
  2. Hamilton Stainless Steel Case Model #15
    By abereiter in forum American Pocket Watches
    Last Post: 12-03-2002, 10:35 AM
  3. Hamilton Factory RR Cases
    By MikeB in forum American Pocket Watches
    Last Post: 09-04-2002, 03:14 PM
  4. One-of-a-kind Hamilton RR Case? Help please.
    By RR Approved in forum American Pocket Watches
    Last Post: 11-15-2000, 09:21 AM
  5. Hamilton RR cases
    By jdsmithnj in forum American Pocket Watches
    Last Post: 09-08-2000, 04:17 PM
