Results 1 to 5 of 5
Thread: Old ITR 24v wall clock.. want to get it running
    DaveD Guest
    Default Old ITR 24v wall clock.. want to get it running
    Greetings,
    I have a old International Time Recording wall clock that runs on 24vDC. I would like to get this running however this is a 3 wire motor, and I don't know what wires go to what. Can I get a 24v dc transformer to run this.. if so how do I hook up the wires.
    Here is a picture of the motor
    http://home.stny.rr.com/davesclocks/DSCF0007.JPG
    thanks,
    Dave
    Nov 2002
    28,736
    canada  ca ontario
    NAWCC
    Hi Dave. What you have is a slave clock that requires a master clock to impulse it once a minute. It appears to have a Simplex movement in it, so it is not totally original. If you google Brian Mumford, he sells timers designed to run clocks like yours.
    Harold
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Oct 2005
    19,614
    usa  us iowa
    NAWCC
    I'm a newby and haven't actually worked on a slave clock, but it appears that your 24 volts will be the two wires on the reddish part of the photo and the other "mystery" wire will get it's power from the master.
    Dave,
    You also might want to post this in the "early electric clocks and watches" forum.
    Nov 2002
    28,736
    canada  ca ontario
    NAWCC
    SB, there is no constant voltage to this clock. It impulses for 2 seconds every minute. The third wire is for hourly correction from the master clock, which also supplies the minute impulses. No master clock impulses, no run. There is no motor, only an impulse solenoid.
    Harold
  1. inherited this clock, would love to get it running.
    By nicholaschase29 in forum Clock Repair
    Last Post: 03-03-2011, 04:20 PM
  2. newbie wants to get started
    By jsisler in forum Watch Repair
    Last Post: 10-27-2005, 12:39 AM
  3. Crossed Arrows on old Movement (Hamburg wall clock)
    By Mike306p/Ansoniaman in forum Clocks General.
    Last Post: 11-19-2002, 12:56 PM
  4. Jno Gill wall clock, mid to late 1700's, info. help!
    By anzer in forum Clocks General.
    Last Post: 10-02-2002, 01:30 PM
  5. Not wanting to get burned
    By canberrablend in forum American Pocket Watches
    Last Post: 02-08-2002, 10:20 AM
