Goal: $300, Received: $40.00 (13%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3806 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Apr 2002
    19,718
    Blog Entries
    Default Crest pocket watch
    I was given a Crest pocket watch, not in running shape.It needs work but is complete.Appears someone sprayed a lubricant of some kind into it.Just smells oily.
    My question what is known of the crest company.This watch is swiss and a 17 jewel about a 12 sz.Any information is helpful.
    Apr 2002
    19,718
    Blog Entries
    Default Crest pocket watch (RE: Kevin W.)
    Does it look like a generic Swiss movement?
    Kent
    That guy down in Georgia
    Registered User doug sinclair's Avatar
    Aug 2000
    Calgary, Alberta
    14,360
    Blog Entries
    The Crest name might have been a house brand of People's Jewellers in Canada. They were the only ones that carried that brand name in Canada. It appears to have been a name that was owned outright by them. They were an average quality, generic Swiss movement in every one I ever recall seeing. It would sound as though a previous owner might heve been "watchmaking" on it. Or It might have had equivalent treatment by a "production" shop.
    Apr 2002
    19,718
    Blog Entries
    Hi Doug.I will try to get it running.It has the Crest name on the case as well.At least it is Canadian as sold by a canadian store.I cleaned it tonight but a curb pin on the regulator is broke and the hairspring seems to be lying on the balance wheel.If i cant get this one going i will look on Ebay for one.I have seen a few of these in antique stores here in Ottawa.
    thanks agin for the information.
  6. #6
    Kevin, You might try looking for an equivalent Swiss movement to get the entire regulator for your watch. I have a variety of generic Swiss watches in my parts and movement boxes, as, I'm sure, others do.
    Can you give us a close up pic of the regulator and the demensions. Maybe one of us would have a regulator you could use.
    Tom
  7. #7
    Apr 2002
    19,718
    Blog Entries
    Here is a picture of the regulator.I will get some dimensions soon for it.
  8. #8
    Registered User Jerry Treiman's Avatar
    Aug 2000
    Los Angeles, CA
    4,758
    I have not been able to find out much about the "Crest" label, but Waltham produced some private-label movements marked "Crest" around 1915.
    "CREST" was also a trademark of the Gruen Watch Co. in the late '30s.
    Jerry Treiman, NAWCC member since 1971
    Charter member of Pocket Horology Chapter 174
  9. #9
    Apr 2002
    19,718
    Blog Entries
    Jerry i wonder why they would put Crest on the movement.Maybe someone,s name in the company? Or to sell to a jeweller with that name?
    Interesting note, my watch case says Crest on it also.
  10. #10
    Aug 2000
    Los Angeles, CA
    4,758
    My movements are from the era when a customer might still pick out his movement and case from a selection presented by the jeweler. Crest was probably a "brand" used by a particular jeweler who wanted the name imprinted on his custom-ordered movements. These may have even been made for the same Canadian retailer or wholesaler who sold your watch.
  11. #11
    Jun 2004
    Edmonton, AB Canada
    64
    I have a private label pocket watch with Crest on the movement. It is a 16s. Engraved on the movement is Crest 19j Adjusted 3 positions U.S. pat 24 may 1904. It has a micrometric regulator and the quality seems to be better then the generic swiss movement. The dial is a ds 24hr with Jackson Bros Jewelery Edmonton, AB. It is cased in a pendant style Fortune AWCCo case with no extra case screw marks so assume original to the movement. Jackson Bros Jewelery was a local store in bussiness from about 1900-1950. I've assumed it was of the 1900 - 1920 vintage and might be a gruen based movement because of the quality but maybe it is too early for that? Doesn't look like any Regina/Omega movements I have seen. Does anyone have any movements they are sure are Crest/Gruen?
  12. #12
    Apr 2002
    19,718
    Blog Entries
    Hi John, sounds like a verry nice watch.And a private label too.Could you possibly post some pictures of it?
    Thanks.
  13. #13
    Aug 2000
    Los Angeles, CA
    4,758
    Joe -- I, too, would enjoy seeing a picture of your watch. I have usually seen the 1904 patent regulator on Vacheron & Constantin movements, such as this example ...
    The 1884 U.S. Patent of this same design was assigned to V&C. I believe the 1904 patent is Swiss. Your high-grade movement may demonstrate who this trademark was used by in Canada (Jackson Bros), or if other jewelers also turn up with the "Crest" label, it may have been a label used by a Canadian wholesaler.
  14. #14
    Jun 2004
    Edmonton, AB Canada
    64
    Jerry and Veritas
    Yesterday when I posted I was working off memory (not the best thing to do) and when I checked the watch last nightfound I got a couple of minor things wrong. There are extra case screw marks on the case so the case is not original to the movement. It's a cashier (25yr) not a fortune (20yr) gf AWCCo case and the dial just reads Edmonton, there is no AB. The engraving on the movement is as I described. The patent information is engraved on the barrel bridge surrounding the ratchet wheel not on the regulator. The regulator is a whip spring type not like the one on the VC you posted Jerry. While it is a decent quality I don't think it is up to the standards of VC - rats you had me going there for a second Jerry. There is currently a Gruen 19 jewel Adj 5 positions on ebay that has a whip spring regulator and Hairspring stud similiar to this Crest which makes me think Gruen likely. I took some pictures last night but I am no photographer and my camera not great. As soon as I can set up a flicker account and figure out how to post pictures I will.
  15. #15
    Jun 2004
    Edmonton, AB Canada
    64
    Trying to post the pics. Here goes.
  1. Crest Pocket watch
    By msb67 in forum European & Other Pocket Watches
    Last Post: 10-13-2011, 10:34 AM
  2. crest pocket watch
    By miner in forum European & Other Pocket Watches
    Last Post: 01-22-2011, 01:57 AM
  3. Hampden Keywind Pocket Watch
    By Wes in forum American Pocket Watches
    Last Post: 01-31-2007, 01:01 PM
  4. Help Identify -- Ricordo Pocket Watch
    By LloydB in forum American Pocket Watches
    Last Post: 01-29-2007, 07:46 AM
  5. James Picard Pocket watch
    By Grantier in forum American Pocket Watches
    Last Post: 02-23-2004, 03:18 AM
