They all face the same way. The Chime and Time wind one way, and the strike winds the other.
Looking at the front of the movement from the right to the left you should have a weight, a chain, a weight, 2 chains, a weight. Does this make sense If not you have one in the wrong place but I don't see how everything could be working correctly as one of the trains would be going in the wrong direction.
Good luck, Bob
On reexamination, I was incorrect. There is one wheel that runs in the opposite position from the others (upside down)
