NOTICE Notice: This is an old thread. The last post was 4416 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 10 of 10
    J.Rogers
    Guest
    Default Jefferson Mystery Clock HELP
    Guys,
    I need a little help.
    My son gave me a nicely refurbed mystery clock for xmas.
    I picked it up in NYC this weekend and it was running fine.
    However, I wrapped it, laided it down in a box, brought it back to Boston in my car.
    Plugged it in when I got home. NOTHING.
    I can hear the motor hum, but the minute hand will not move and the counter weight for the Hr hand swings free as it is suppose too.
    I hate to take it apart blind without a little adult guidance.\
    Any thoughts you might have would be appreciated.
    J.Rogers
    Guest
    Default Jefferson Mystery Clock HELP (RE: J.Rogers)
    Guys,
    Registered user.
    Jan 2001
    Campbell River, B.C. Canada
    755
    Hi J.
    This may get more response on the electrical horology board, but here goes. Do you have a Timesavers catalogue? At the back of the catalogue are complete instructions on how to disassemble and reassemble the Golden Hour. If the motor is functional, it is generally the glass and gear ring which become separated from each other. You will need to reglue, or replace if this is the case.
    Cheers,
    Doug
    J.Rogers
    Guest
    Doug,
    I don't have a copy of the catalog, I found a ref on the internet. Is there a catalog ref# like #26, or #30 that shows the detail you were referring too. any help would be appreciated
    Registered User Scottie-TX's Avatar
    Apr 2004
    Mesquite, TX
    938
    www.timesavers.com or 800 552 1520 if you want a dead tree edition .
  6. #6
    J.Rogers
    Guest
    Scottie,
    Thanks, found what I was looking for. Have the instructions for repair, now just have to diagnose the problem.
  7. #7
    David Holk
    Guest
    I would not be surprised to find that the gear had come loose from the glass. I had good success glueing this with slow cure epoxy.
    David
  8. #8
    J.Rogers
    Guest
    david,
    The problem is that the motor hums, and that bothers me. According to my son, the place he got it from just retored it which bothers me.
    I will take the gear out and look at it. But if it is the motor it is small $$$.
    I found the instructions for assy/ disassy and will take it apart to look at it
  9. #9
    J.Rogers
    Guest
    Here is what i have done and found out.
    1. when you remove the ring gear plate the shaft gear on the motor turns.
    2. Ring gear is attached to the glass, no problem
    3. when you lay the ring gear down and engage the gear mesh on the motor shaft to the gear teeth on the ring gear, motor will not turn the ring gear plate.
    I did this just lying flat so I could see the turn, no pressure with the retaining ring.
    CONCLSUION: The motor requires replacement.
    Anybody else have a different conclsion or suggestion
  10. #10
    J.Rogers
    Guest
    Well,
    The new motor arrived, and the clock is now running like a fine wristwatch.These things are a bear to adjust took a lot of tinkering time to get it to run correctly.
  1. Help ID Required Mystery Clock
    By testguy in forum Clocks General.
    Last Post: 08-09-2011, 02:08 PM
  2. Jefferson Golden Hour Clock - Help
    By harold in forum Electric Horology
    Last Post: 12-30-2010, 07:00 PM
  3. Mysterious "W/H" Clock ... Help!
    By RealBoatsRock in forum Clocks General.
    Last Post: 09-28-2009, 01:02 AM
  4. Help please to identify mystery clock
    By hugha in forum Clocks General.
    Last Post: 01-17-2009, 04:30 PM
  5. Mystery Clock: Help, Please!
    By Riada in forum Clocks General.
    Last Post: 07-24-2008, 07:58 AM
Members who have read this thread: 0
There are no members to list at the moment.
