Goal: $300, Received: $30.00 (10%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 4954 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    proconsul
    Guest
    Default Correct Movement for Ansonia Porcelain Clock?
    I have an Ansonia porcelain clock case with a rococo sash bezel and plain, as opposed to outside escapement, dial and nothing else, not even a gong. Can anyone tell me what the right movement is for this clock and how it is fixed in the case? The back of the dial has no posts to pin a movement to, and the dial itself just sits in the front opening with a friction fit.
    Thanks,
    Steve
    proconsul
    Guest
    Default Correct Movement for Ansonia Porcelain Clock? (By: proconsul)
    Thanks,
    Steve
    Hi Steve,
    There is a frame that clamps onto the front porcelain opening in three places. Cardboard is placed between the brass plates that form the three clamps and the porcelain case. Bolts that thread into the frame are used to tighten the clamps.Overtightening of these clamps is what cracks cases. The movement bolts to the frame.I could post some pictures if you would like. John
    proconsul
    Guest
    Once again, many thanks for the thoughtful, helpful, and detailed replies.
    Steve
  1. Movement for Self-Winding Clock Needed
    By Frank Lindauer in forum Clocks General.
    Last Post: 07-15-2005, 01:23 AM
  2. Ansonia porcelain clock---name of model
    By Mike306p/Ansoniaman in forum Clocks General.
    Last Post: 12-21-2003, 05:36 AM
  3. ansonia porcelain clock
    By timelyrestorations in forum Clocks General.
    Last Post: 11-07-2003, 09:48 AM
  4. Main spring for Ansonia Porcelain Clock
    By Donald P Bellamy in forum Clock Repair
    Last Post: 11-02-2003, 08:05 AM
  5. Bust For Ansonia "Euclid" Clock
    By Don DeMarcus in forum Clocks General.
    Last Post: 02-17-2003, 11:03 AM
Members who have read this thread: 0
There are no members to list at the moment.
