Goal: $300, Received: $250.00 (84%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3733 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Default Haddon Golden Vision
    Is there an expert out there with the Haddon Golden Vision clock, the knock-off of the Jefferson Golden Hour? The motor on my Haddon seems okay, but there is some friction in the dial glass/minute hand assembly that is causing a problem. Thanks.
    Frank Lindauer
    Frank Lindauer
    Cad49@bellsouth.net
    Default Haddon Golden Vision (RE: Frank Lindauer)
    Frank Lindauer
    Frank Lindauer
    Cad49@bellsouth.net
    Charles Vesser
    Guest
    Hi Frank,
    No expert here on Haddons but I had the same problem on mine.
    I fixed it but I am not sure which of the 3 procedures was the problem.
    (1) I took 600 sandpaper and sanded all around the edge of the glass just to polish it.
    (2) I sanded the steel ring that goes in the circle of the clock nice and smooth including the edges putting a light coat of oil on it and wipeing it off.
    (3) I sanded the inside of the housing where the class fits and then polished it.
    I think those frames the glass goes in are some kind of potmetal substance. I'm not for sure that they don't start shrinking or swelling over the years.
    But to answer your question one of the three operations above will usually be the problem. Just make all three pieces as slick and smooth as possiable.
  1. Haddon Golden Vision Replacement Motor
    By steve102 in forum Electric Horology
    Last Post: 05-10-2014, 02:54 PM
  2. Need a good motor for a Haddon Golden Visionette
    By Frank Lindauer in forum Electric Horology
    Last Post: 12-28-2011, 06:51 PM
  3. Motor for Haddon Golden Hour
    By dutch in forum Electric Horology
    Last Post: 01-07-2006, 04:01 AM
  4. Vision impaired person's watch
    By Steve Maddox in forum American Pocket Watches
    Last Post: 08-29-2001, 03:52 AM
  5. Haddon Model 30 Home Sweet Home Clock
    By lpbp in forum Horological Misc
    Last Post: 12-21-2000, 09:57 AM
