NOTICE Notice: This is an old thread. The last post was 4504 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    david bishop
    Guest
    Default let- down tool- homemade?
    Hi
    I've seen the let- down tool in the s larose catalog and was wondering if anyone has attempted to make a similar ( or not-so similar) tool themselves. Using a simple key to let down a mainspring is ok for occasional use but frustrating when you've got a few clocks. I think I've also seen somewhere that you can make a holder to hold the winged keys and was wondering if people find this method ok ( and safe).
    David
    david bishop
    Guest
    Default let- down tool- homemade? (By: david bishop)
    Hi
    David
    Apr 2004
    Mesquite, TX
    938
    Sure. Why not . I've done it. Probly most of us have. A decent supply of keys: Saw a slot in any kind of handle . . . . This just isn't the place to save money. The letdown handle and associated keys don't cost much and are safe. You know the ansswer is: "No the makeshift letdown is NOT safe." Save money somewhere else.
    May 2003
    Stanwood, Mi.
    305
    An inexpensive set of let downs would be the safest.
    Registered User doug sinclair's Avatar
    Aug 2000
    Calgary, Alberta
    14,368
    Blog Entries
    David,
    Another consideration: You don't say whether you have a mainspring winder or not, but the let down key with interchangeable arbors is necessary with mainspring winders such as the Ollie Baker. The aforementioned let down tool is much safer in the case of an accident than an adapter that uses a regular key. Both for the fingers and the clock.
  6. #6
    david bishop
    Guest
    Thanks for the replies.
    I appreciate the comments on the safety aspects. I also had wondered if someone had come up with an improved method of letting down mainsprings, especially given the different arbor sizes and the fact that some arbors, when burred, are no longer true to size.
    Doug, I do have a winder but it's not the Ollie Baker type. It's the older type and I picked it up at an auction years ago. It too can be dangerous- in the wrong hands- but I treat it with the respect that it deserves!
    Regards
    David
  1. Letting down the mainspring on a Waltham cal 1891
    By AnthonyR in forum American Pocket Watches
    Last Post: 09-29-2005, 09:19 AM
  2. American Pocket Watch Letting down Waltham 1883
    By Luca in forum Watch Repair
    Last Post: 09-10-2005, 03:12 AM
  3. ITR let down tool?
    By Dave Robertson (no relati in forum Horological Tools
    Last Post: 08-05-2004, 05:27 PM
  4. Lux Time only/Let down mainspring?
    By gary G in forum Clock Repair
    Last Post: 06-16-2004, 07:56 AM
  5. Letting down the mainspring
    By Wayne C. Anderson in forum American Pocket Watches
    Last Post: 10-12-2002, 06:18 AM
Members who have read this thread: 8
