NOTICE Notice: This is an old thread. The last post was 4677 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Default Jan 25 1881 patented clock found in church
    Found in church: a 2" wide X 2"depth X 4" high
    with tin case, square dial, triangular movement,
    with dial above space that reads,
    "Pat. Jan 25 1881." Probably not many around. I would like to repair it for the churchs 150th year celebration next summer. It works fine but I need to know what kind of pendulum it needs. In order to clear whatever it sits on I am thinking it is a bullet time that threads on to the pend. rod. Any ideas will help. Thanks
    Default Jan 25 1881 patented clock found in church (By: Frederick)
    Principal Administrator John Hubby's Avatar
    Sep 2000
    The Woodlands, TX
    11,004
    Frederick, it would help a lot if you could post some photos of your clock here.
    John Hubby, Secretary
    The International 400-Day Clock Chapter #168
    Frederick,
    It's all in the name.....
    The patent probably belongs to a Frederic A Lane, of New Haven Ct, #237,028.
    The patent reads that it's purpose was to make a compact clock without fine gearing.
    You can look up the patent at:
    http://patft.uspto.gov/netahtml/srchnum.htm
    Ralph
  1. clock found after years in cupboard ?
    By steve@cuba? in forum Your Newest Clock Acquisition
    Last Post: 01-04-2010, 05:13 AM
  2. Old Clock found in Jacksonville, FL
    By JaxNut in forum Clocks General.
    Last Post: 07-19-2007, 11:43 AM
  3. Odd & Interesting Things found in clocks...
    By Arthur Cagle in forum Clocks General.
    Last Post: 11-04-2006, 12:21 PM
  4. Any Old Clocks Made In Kentucky?
    By ShawnHVoils in forum Clocks General.
    Last Post: 06-29-2005, 09:10 PM
  5. Dating clock parts found in excavation
    By Andy Krietzer in forum Horological Misc
    Last Post: 12-26-2001, 06:28 AM
