Results 1 to 5 of 5
Thread: Need help removing rear cover on Swiss Army Watch
    Default Need help removing rear cover on Swiss Army Watch
    I recently purchased a Swiss Army Pocket Watch. It has a quartz movement and the battery needs to be replaced. Could someone tell me how to remove the rear cover so I could replace the battery?
    Many thanks.
    Patrick Roach
    Member # 12619
    Many thanks.
    Patrick Roach
    Member # 12619
  3. Default Need help removing rear cover on Swiss Army Watch
    If this is like the wrist watches,some of them are a bear to remove.I use the blade of a beauticians razor blade to get the back started off.Then use my regular bench knife.
    I get the razor blades,used, from a beauty shop down the street.They are stronger and the blade is not as wide as a mans razor blade.
    Hope this helps.
    J Smith
    Thanks for the reply Julian. I doubt the pocket watch is the same as the wrist watch. A razor blade would be useless on the Pocket watch. I'm 99% sure (just by looking at it) that the back is not a screw back, but I have no clue as to whether I need a special tool to "pry" off the back cover. I'm hoping someone will respond who has actually encountered one of these and successfully removed the back.
    pj,
    A word of warning from someone who has tried.
    I have at times held a watch up on edge on a good protective surface-thentook a case knife that fits in the groove and given the knife several teps with a small hammer to get it started. It can be done but you will feel like you need 3 hands to do it. Now back to the warning----Swiss Army,Fossil and some other brands are famous for being a real bugger bear when it comes to replacing the back. So if you get the back off--putting it back on will be a challenge --even with a case back press---GOOD LUCK
  1. Need Help Identifying Swiss Army Watch!
    By MikeKalil in forum Wrist Watches
    Last Post: 08-05-2011, 06:36 PM
  2. Need help removing 8-day Swiss PW Spring
    By bchaps in forum Watch Repair
    Last Post: 10-20-2009, 10:58 AM
  3. Need help with manual wind on auto Omega 1040
    By Steve Cary in forum Watch Repair
    Last Post: 12-13-2005, 05:44 AM
  4. Translation needed on Swiss Pocket watch
    By Doug Campbell in forum American Pocket Watches
    Last Post: 09-26-2004, 09:22 AM
  5. Need Help Tracking Down a Swiss Army Watch
    By lamarw in forum Wrist Watches
    Last Post: 03-23-2004, 09:22 AM
