NOTICE Notice: This is an old thread. The last post was 5122 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Lorie
    Guest
    Default Junghans strike assembly
    I have, on the bench, a Junghans time and strike wall clock movement. I am not able to re-assemble the hammer lifting mechanism in it's correct order. I believe it was put together wrong (didn't work) when I got the clock. I'm not able, yet, to follow Junghan's thinking on how this should work. Is there a source out there somewhere which would outline the movement? or have pictures? I'm sure it will be painfully obvious when I'm done. Thank you
    Lorie
    Guest
    Default Junghans strike assembly (RE: Lorie)
    Lorie
    Guest
    It's rack and snail. Two chime rods hanging vertically in the wallclock case, two hammers. Hammers attach to the movement, um like a Westminster hammer setup.
    Lorie
    Guest
    Phil, thank you for your time and for your advice. It is a bim-bam strike and you are correct in your assumption of the mechanics of the movement. So, back to the movement and follow your guidance. Thank you.
  1. Junghans strike adjustment
    By Dave P in forum Clock Repair
    Last Post: 05-05-2008, 12:12 AM
  2. Junghans strikes too early
    By Warrie in forum Clock Repair
    Last Post: 01-04-2008, 02:17 PM
  3. Junghan strike set-up problem
    By TonyR in forum Clock Repair
    Last Post: 02-03-2006, 01:56 PM
  4. Junghans Strike governor fan
    By Paul FM TX in forum Clock Repair
    Last Post: 12-14-2004, 05:45 PM
  5. Junghans strike problem
    By DenisG in forum Clock Repair
    Last Post: 01-07-2004, 07:34 AM
Members who have read this thread: 0
There are no members to list at the moment.
