NOTICE Notice: This is an old thread. The last post was 5251 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    Chris McVetty
    Guest
    Default Fusee cable question
    I have received an English Fusee in for repair with the catgut cable broken. I'm trying to determine the best material to use to replace this. Does anybody know if there is a better method of curing catgut than olive oil?
    Thanks for any help
    Chris
    Chris McVetty
    Guest
    Default Fusee cable question (By: Chris McVetty)
    Thanks for any help
    Chris
    You and your customer should get together on the decision to replace the original gut fusee cord with either the same gauge animal gut, monofilament fish line or bronze cable. Each has it's own advantage.
    My own thought is to replace it with animal gut the same as it was originally. If, however you determine that it was originally a metal link fusee chain, then your customer should help you decide to pursue obtaining a suitable fusee chain.
    I understand that many fusee chains were, in the past, "canabalized" and gut, wire and other make-shift lines were substituted. Inspection of the spring barrel and the fusee should reveal if the movement was originally gut or metal fusee chain.
    Your query asks about olive oil to cure animal gut fusee line. I don't know how to reply except to comment that olive oil, like most animal and vegetable oils, will in time oxidize and form a sticky goo that eventually hardens. If the objective is to keep the gut pliable, then a mineral oil would serve best in my opinion. And of those, Mobil-1 would be my choice.
    PS: I don't have any chains.
    Les
    H.J. (Les) Lesovsky, Alhambra California
    The quality of animal gut cord found on the market today is not particularly good, in my opinion. I agree with Gunther that whatever cord you use will not affect the value of the clock, that is, unless it breaks. With that in mind, I would follow Les's advice and figure out whether it had gut or chain originally, and proceed from there. If it were my clock I would not risk using real gut, and I certainly would not use an oil that may give you trouble down the road.
    jim
    Chris McVetty
    Guest
    I appreciate all the input. I have determined that this clock originally had gut from the manner in which the fusee is cut, and mainly am deliberating on the best replacement for the gut. I'm not real comfortable using the current gut available, as I don't want my repairs lasting only several years as the last one did. Does anyone have a recommendation on a good source for steel cable?
    Thanks all,
    Chris
  1. Fusee PW Questions "Kilmarnock"
    By Turpentime in forum European & Other Pocket Watches
    Last Post: 05-13-2009, 01:12 PM
  2. gut cable question
    By harold bain in forum Clock Repair
    Last Post: 10-17-2007, 10:42 AM
  3. Fusee cable
    By cucoclock in forum Clock Repair
    Last Post: 12-27-2006, 06:21 PM
  4. Brass Cable Questions
    By Rookie in forum Clock Repair
    Last Post: 08-08-2004, 01:30 AM
  5. cable question
    By timelyrestorations in forum Clock Repair
    Last Post: 10-29-2003, 02:39 AM
Members who have read this thread: 4
