Goal: $300, Received: $175.00 (58%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3903 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Rich
    Guest
    Default Viceroy by Ingraham
    Hi!
    What you have is a 'Viceroy' model, manufactured by the E. Ingraham Company who were in business until 1958. Ingraham produced several million watches ? so far as I know, most if not all of their watches were of the unjewelled 'Dollar Watch' category.
    'Dollar Watches' have been discussed here on many occasions as you will discover if you take advantage of the search facility found near the top right of this page. However, to give you a start in the right direction, here are a few relevant links.
    http://www.nawcc.org/ubb/Forum3/HTML/000558.html
    http://www.nawcc.org/ubb/Forum3/HTML/001309.html
    http://www.nawcc.org/ubb/Forum3/HTML/002448.html
    Good Hunting!
    'Rich'
    #149591
    Default Viceroy by Ingraham (RE: Rich)
    Rich, May I offer a humble correction to your post? The Ingraham Company went out of business in 1968, not 1958. Tom
    Rich
    Guest
    Tom writes:
    "The Ingraham Company went out of business in 1968, not 1958......."
    Just testing ya with a deliberate mistake, Tom! I wondered how long it would take you to spot it......
    'Rich'
    #149591
    lots of time
    Guest
    Hmmmmmmmm... You work for Shugart Rich
    Forenum, To find out how old it is, use a knife and pry off the back. It should just snap off. On the movement, you will see some numbers stamped, ie 65 and a 4, meaning April 1965. A caution to you. When snapping the back into place, do not put any pressure on the crystal when you do it. even though the crystal is plastic, the pressure can crack it. Tom
  6. #6
    Wm. Enestvedt
    Guest
    Can anyone tell me how to munge the above URLs to read more about the Ingraham dollar watches?
    I have an Ingraham Viceroy that is my dad's but which no longer works. I dropped it off at the Prvidence Watch Hospital to get an estimate for cleaning it out and getting the stem reseated so it will work again (or whatever the real problem is) as a surprise for him.
    I'm beginning to fear it will be money down the drain. :7(
    I haven't taken off the back to check the year; when they call with the estimate I will ask them.
    How much should I expect to pasy for this, bearing in mind that it's *all* sentimental value? :7)
    It looks exactly like the image in this June 2006 Ebay auction:
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=8949970057
  1. Ingraham Viceroy - advice?
    By Firepowerforfreedom in forum American Pocket Watches
    Last Post: 10-13-2011, 08:34 PM
  2. Pocket Watch carried by Priests.
    By PAMELLA in forum American Pocket Watches
    Last Post: 10-09-2006, 08:00 AM
  3. Any info on clocks by John Breese (British) Maker
    By Jeff Salmon in forum Clocks General.
    Last Post: 09-29-2006, 03:23 PM
  4. BOOKREVIEW: Extreme Restoration / An e-book by Tom E. Temple / published 2005
    By Fortunat Mueller-Maerki in forum Horological Books
    Last Post: 07-11-2005, 11:29 PM
  5. Ingraham "Viceroy" hairspring needed
    By Chris in forum American Pocket Watches
    Last Post: 07-12-2004, 08:35 PM
Members who have read this thread: 0
There are no members to list at the moment.
